Help!!!!The process android.process.media has stopped unexpectedly. please try again?
This is a discussion on Help!!!!The process android.process.media has stopped unexpectedly. please try again? within the Droid X Help forums, part of the Droid X Discussion category; Hello everyone, I try to SBF my droid x back to foyor by following ---http://www.droidxforums.com/forum/droid-x-sbf/22394-sbf-detailed-guide-success-windows-7-a.html this link. I was using vista! so after everything is ...
Results 1 to 8 of 8
  • 1 Post By mikeinrichmond
Thread: Help!!!!The process android.process.media has stopped unexpectedly. please try again?
    Points: 281, Level: 5
    Level completed: 62%, Points required for next Level: 19
    hijacksu's Avatar
    41462
    Hello everyone,
    I try to SBF my droid x back to foyor by following ---http://www.droidxforums.com/forum/droid-x-sbf/22394-sbf-detailed-guide-success-windows-7-a.html this link. I was using vista! so after everything is done my phone is having this problem"sorry, The process android.process.media has stopped unexpectedly. please try again?" I try to re do the SBF but is no finding phone already!!! Please help me if you know anything!!
    Thank you
    hijacksu's Avatar
    41462
    Exclamation Help! "the process android. process media has stopped unexpectedly. please try again"
    Hello everyone,
    Please help me my phone keep showing "sorry! the process android. process. media has stopped unexpectedly. please try again." After I did the SBF from this link "http://www.droidxforums.com/forum/droid-x-sbf/22394-sbf-detailed-guide-success-windows-7-a.html"
    Please help me if you can!!
    Points: 8,559, Level: 62
    Level completed: 37%, Points required for next Level: 191
    Nerdslogic's Avatar
    37837
    Cybertron
    1,282
    59 times
    I have done a lot of write up's....here's a link to some. If you would like help with your phone simply ask, PM me, or drop me an email and I will assist where I can.
    List of phones I can help with: Droid, Droid 2, Droid 2 Global, Droid X, Droid X2, Droid 3, Droid Bionic.
    If you don't get response here try me on DroidForums, XDA, or Rootzwiki under the same name
    Points: 15,172, Level: 79
    Overall activity: 14.0%
    cory46's Avatar
    8051
    4,768
    125 times
    Try this
    Applications> download manager and clear data and cache
    Or settings> applications> manage> all click media storage and cheat data / cache
    I haz interwebz
    Moderator
    Points: 25,450, Level: 96
    Frequent Poster
    mikeinrichmond's Avatar
    9010
    Richmond, Va
    7,668
    392 times
    Did you do a factory reset after the SBF? If not, here's the procedure:
    Pull the battery, replace, then hold the home button then press and hold the power button until the android guy with the triangle shows up. Hit the search key, use the volume buttons to scroll down to wipe data/factory reset, choose it with the camera button, scroll down to yes, and choose it. It will do it's thing for about a minute. Hit the back button, then goto reboot and click it. When it boots back up you should be fine..
    hijacksu likes this.
    Moderator
    Frequent Poster
    9010
    Richmond, Va
    7,668
    392 times
    threads merged, please do not post the same question to multiple subforums...
    hijacksu's Avatar
    41462
    Quote Originally Posted by mikeinrichmond View Post
    I m sorry I m new here and I was in a rush! After I post the first one and I didnt find it so I did another one!! It wont happen again.
    hijacksu's Avatar
    41462
    I tried this method a few days ago and it worked, So thank you anyway.
  1. Replies: 4
    Last Post: 10-25-2011, 09:16 PM
  2. Process gapps has stopped
    By Money Mike in forum Gingerbread Help
    Last Post: 04-20-2011, 08:49 PM
  3. Processes com.android.settings has stopped unexpectedly
    By SVDroidDude in forum Droid X Help
    Last Post: 01-12-2011, 01:34 PM
  4. Replies: 7
    Last Post: 11-18-2010, 04:11 PM
  5. Replies: 2
    Last Post: 10-03-2010, 10:25 PM
sorry the process android.process.media has stopped
sorry the process android.process.media has stopped unexpectedly
sorry the process android.process.media has stopped unexpectedly. please try again
the application download manager has stopped unexpectedly
