gmail.... NO CONNECTION
This is a discussion on gmail.... NO CONNECTION within the Droid X Help forums, part of the Droid X Discussion category; Yesterday gmail was working fine.... this morning gmail won't CONNECT.... it just says NO CONNECTION at the bottom.... my wifi is turned on and all ...
Thread: gmail.... NO CONNECTION
    250 Experience Points100 Experience Points31 days registered7 days registered
    novaqueen20's Avatar
    3758
    11
    Yesterday gmail was working fine.... this morning gmail won't CONNECT.... it just says NO CONNECTION at the bottom.... my wifi is turned on and all everything else is working... the browser, facebook, my other email account I'm not sure is working either.
    I've tried resyncing and I tried deleting the gmail account and redoing it, but it won't let me.
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    Try this...
    Go into gmail - press the hard menu button - select accounts - hard menu button - select account settings - make sure that background data and auto-sync are checked. You can also go ahead at this point and tap on your google account (listed under manage accounts) and make sure that all three of the options (contacts, gmail, calendar) are checked - hard menu button again and press sync now.
    500 Experience PointsTagger Second Class250 Experience Points7 days registered100 Experience Points
    jmartinez06's Avatar
    39
    306
    17 times
    Try hitt ing *22899 and reboot
    The world shall be destroyed... By Captain Planet!!!!
    3758
    11
    I don't really want to reboot....
    I've tried resyncing and I've found some solutions to this problem, but they don't work for me.... I don't know what to do!
    20,509
    885 times
    Novaqueen, just to clarify - a reboot is turning the phone off & on (battery pull - if ya want).
  1. Wi-Fi Connection WPA
    By droidxfan in forum Droid X Help
    Last Post: 09-17-2010, 09:02 AM
  2. USB Connection unmounting sd card
    By soktwin1 in forum Droid X Help
    Last Post: 09-12-2010, 04:44 PM
  3. PdaNet Bluetooth DUN Connection?
    By dylan727 in forum Droid X Apps
    Last Post: 08-09-2010, 10:16 AM
  4. USB Connection to PC is Constantly Failing...
    By AggieX in forum Droid X Help
    Last Post: 07-25-2010, 08:31 PM
  5. Connection available alert.
    By PorcPuffer in forum Droid X Help
    Last Post: 07-21-2010, 07:16 AM
droid gmail no connection
droid gmail won't connect
droid won't connect to gmail account
droid x gmail no connection
droid x wont connect to gmail
gmail no connection
gmail no connection on droid
gmail won't connect on droid
gmail wont connect on droid
no gmail on droid
