How do you manually reboot the Droid X?
This is a discussion on How do you manually reboot the Droid X? within the Droid X Help forums, part of the Droid X Discussion category; On the iPhone it is as simple as holding down the Home button and the power button at the same time. On the Droid X ...
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Like Tree2Likes
Thread: How do you manually reboot the Droid X?
    Points: 3,485, Level: 36
    Level completed: 90%, Points required for next Level: 15
    Hephaestus's Avatar
    2795
    Portland, Oregon
    32
    On the Droid X do you just hold the power button down until it shuts down and then push again to start up? Is that considered a hard reset?
    Are there both hard resets and soft resets on the Droid X?
    Thanks!
    Points: 5,228, Level: 46
    Level completed: 39%, Points required for next Level: 122
    thescreensavers's Avatar
    268
    Miami,FL
    464
    48 times
    Turning off, Taking out the battery = Soft Reset/Reboot
    Factory Data Reset = Hard reset
    Hephaestus likes this.
    Droid Does
    Points: 4,469, Level: 42
    Level completed: 60%, Points required for next Level: 81
    BOWIE's Avatar
    1078
    Scottsdale, AZ
    603
    39 times
    Quote Originally Posted by Hephaestus View Post
    Yes, you just hold down the power button. No, it's the soft reset mentioned above.
    Hephaestus's Avatar
    2795
    Portland, Oregon
    32
    Thank you both. Is there a recommendation to do a soft reset once a month or does it matter for optimal performance?
    BOWIE's Avatar
    1078
    Scottsdale, AZ
    603
    39 times
    Great question. I haven't seen anything official so I won't speculate.
    I have to turn mine off and on every few days because of apps glitching anyhow.
    Points: 1,864, Level: 25
    Level completed: 64%, Points required for next Level: 36
    pocopine's Avatar
    3300
    27
    I used to use QuickPull on my BB Curve to reboot the phone everyday, but there's nothing like that for the DX (unless you're rooted). I've read several posters who have hundreds of hours of up-time between reboots and all is well. I think it might depend on what apps you have downloaded and are using. If you're not having any problems, I'd just leave the phone on. Then again, shutting the phone off can't hurt, can it?
    500 Experience PointsTagger Second Class250 Experience Points7 days registered100 Experience Points
    jmartinez06's Avatar
    39
    306
    16 times
    You want to do a soft reset at least once a week to clear the dns cache.
    The world shall be destroyed... By Captain Planet!!!!
    Points: 1,569, Level: 22
    Level completed: 69%, Points required for next Level: 31
    Trash Can's Avatar
    71
    130
    Quote Originally Posted by jmartinez06 View Post
    In case anyone was wondering, that pretty much goes for any smart phone, not just the X.
    dont work on my verizon x
    USMC_jd's Avatar
    1833
    87
    You dont have to pull your battery for a soft reset with the X. Just turning off and turning back on will do the job.
  1. Resending SMS Text after Reboot
    By mnasholm in forum Droid X General Discussion
    Last Post: 07-05-2011, 11:51 PM
  2. Manually change orientation of screen
    By eugdroidx in forum Droid X General Discussion
    Last Post: 07-23-2010, 07:04 PM
  3. 7 days on the DX without a reboot.
    By tourrider in forum Droid X General Discussion
    Last Post: 07-23-2010, 12:25 AM
droid x reboot
droid x reset
droid x soft reset
how to reboot droid x
how to reset a droid x
how to reset droid x
how to restart droid x
reboot droid x
reset droid x
soft reset droid x
