My X wont boot into CW
This is a discussion on My X wont boot into CW within the Droid X Help forums, part of the Droid X Discussion category; Originally Posted by slosho My D2 bootstrapper won't allow me to select anything... when I do the screen goes blank ( I want to SBF ...
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
Like Tree2Likes
Thread: My X wont boot into CW
  1. #21
    Points: 15,172, Level: 79
    Overall activity: 14.0%
    cory46's Avatar
    8051
    4,768
    125 times
    Quote Originally Posted by slosho View Post
    My D2 bootstrapper won't allow me to select anything... when I do the screen goes blank ( I want to SBF so I can install 596)
    If you're going to sbf already there isn't a need to open up bootsrtap.
    Just get your preferred method of sbf either Linux disk or rsd lite sbf flash away
    I haz interwebz
  3. #22
    Super Mod Team Lead
    Points: 23,961, Level: 94
    Level completed: 62%, Points required for next Level: 389
    Overall activity: 44.1%
    jwalz's Avatar
    34326
    7,603
    296 times
    Quote Originally Posted by cory46 View Post
    So just for clarity
    You sbf
    Re rooted
    Now droid x bootstrap won't go into clockwork
    Do you have titanium backup on your device?
    If so open it and hit the problems button and see if busybox will update
    Busybox is a "toolbox" in a sense it contains and allows root programs to perform functions
    I haz interwebz
    did not need busybox needed rom manager and to update superuser.....busybox just bootlooped me to hell.lol not sure why but when i dl rom mgr and updated my dx bootstrapper worked fine....thank you for all your input everyone..love dxf
    edit...there is no way i could not do any of this with out my man MICHO. dude knows his sh!t and was able to get me up and running in a matter of minutes and why he is not part of you RS is beyond me and a loss to DXF...thanks alot bro you the man
  4. #23
    Points: 480, Level: 9
    Level completed: 60%, Points required for next Level: 20
    slosho's Avatar
    31921
    Ok, so If I don't SBF and I have a problem. No big deal? I did use Ti Backup. Also if I cannot select anything, so how will I be able to install 596?
    Thanks for all the help!
  5. #24
    RS Team Leader
    Points: 26,927, Level: 97
    Level completed: 58%, Points required for next Level: 423
    Overall activity: 99.9%
    Activity Award
    popcenator's Avatar
    21238
    Omaha, NE
    8,258
    179 times
    Yeah, MICHO is the man, forgot about the superuser update.
    on the move..
  6. #25
    RS Team Leader
    Activity Award
    popcenator's Avatar
    21238
    Omaha, NE
    8,258
    179 times
    Look in the market for an update to superuser or open SU and go to settings, go to the bottom and hit superuser 2.3.6.x
    on the move..
  7. #26
    slosho's Avatar
    31921
    Quote Originally Posted by popcenator View Post
    on the move..
    Since it had already been suggested in this thread, I had already updated my su I also installed jrummy16's free busy box. Still the problem of not being able to select anything when using cwm...
    And does sbfing make a copy that i can recover to? Or I'd it just a recovery tool? Of I don't need to sbf I won't.
    Thanks again for the help
  8. #27
    RS Team Leader
    Activity Award
    popcenator's Avatar
    21238
    Omaha, NE
    8,258
    179 times
    Check the superuser app to see if D2 Bootstrap recovery is in there.
    Are you able to boot into clockwork and then it won't do anything or is the screen going blank after pressing reboot recovery?
  9. #28
    slosho's Avatar
    31921
    The bootstrapper is in su and has root access..
    when I boot into recovery I get the menu but I cannot select anything with the power button. when I do select something I get a black screen.
    I have to do a battery pull to get out.
  10. #29
    Points: 19,500, Level: 88
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    In clockwork, you use the camera button to select...the power button turns the screen off.
    slosho likes this.
  11. #30
    slosho's Avatar
    31921
    Quote Originally Posted by C Dippa View Post
    Facepalm!
    Thanks!
    one last question do I need to SBF first if i used Ti backup?
    *edit* just used nandroid to create a backup. but the question remains for me. do I need to SBF prior to the install of 596.
  1. Apex 1.4.0 - wont get past boot animation! Help!
    By Mqureshi79 in forum Droid X ROMs
    Last Post: 02-20-2012, 11:58 PM
  2. After flashing crt phone wont boot! please help
    By tycoon177 in forum Gingerbread Help
    Last Post: 05-22-2011, 01:26 AM
  3. liberty boot icon wont change using toolbox
    By t.noroeste in forum Droid X Help
    Last Post: 02-20-2011, 07:45 AM
  4. droid x wont boot up
    By rudolfthered in forum Droid X Rescue Squad
    Last Post: 02-13-2011, 02:41 PM
  5. HELP!!! Droid x wont boot after moto logo
    By mikejones396 in forum Droid X Help
    Last Post: 11-05-2010, 01:08 AM
droid x 602 blank screen on clockwork
