If you're going to sbf already there isn't a need to open up bootsrtap.
Just get your preferred method of sbf either Linux disk or rsd lite sbf flash away
I haz interwebz
Printable View
did not need busybox needed rom manager and to update superuser.....busybox just bootlooped me to hell.lol not sure why but when i dl rom mgr and updated my dx bootstrapper worked fine....thank you for all your input everyone..love dxf
edit...there is no way i could not do any of this with out my man MICHO. dude knows his sh!t and was able to get me up and running in a matter of minutes and why he is not part of you RS is beyond me and a loss to DXF...thanks alot bro you the man
Ok, so If I don't SBF and I have a problem. No big deal? I did use Ti Backup. Also if I cannot select anything, so how will I be able to install 596?
Thanks for all the help!
Yeah, MICHO is the man, forgot about the superuser update.
on the move..
Since it had already been suggested in this thread, I had already updated my su I also installed jrummy16's free busy box. Still the problem of not being able to select anything when using cwm...
And does sbfing make a copy that i can recover to? Or I'd it just a recovery tool? Of I don't need to sbf I won't.
Thanks again for the help
Check the superuser app to see if D2 Bootstrap recovery is in there.
Are you able to boot into clockwork and then it won't do anything or is the screen going blank after pressing reboot recovery?
The bootstrapper is in su and has root access..
when I boot into recovery I get the menu but I cannot select anything with the power button. when I do select something I get a black screen.
I have to do a battery pull to get out.
In clockwork, you use the camera button to select...the power button turns the screen off.
