Cell Standby Draining Battery - Anyone else?
This is a discussion on Cell Standby Draining Battery - Anyone else? within the Droid X Help forums, part of the Droid X Discussion category; As you'll see from the image, the "cell standby" drained my battery by 20% within about 3 hours. This is with wi-fi & background data ...
Results 1 to 10 of 11
Thread: Cell Standby Draining Battery - Anyone else?
    As you'll see from the image, the "cell standby" drained my battery by 20% within about 3 hours. This is with wi-fi & background data turned off. Is this what is expected from the Droid X?
    It's already a shame that I can't have the regular functions of the phone running without greatly draining battery, but I'm lost on how to keep the battery from being drained without cutting myself off from the world (turning off phone, or putting it in airplane mode). What's the phone of owning a phone if it can't accept calls and messages? I already have to have my screen on the dimmest setting, wi-fi off, backround data off, and data timeout on 15 minutes.
    This is my first Droid phone; does the Incredible have this issue? Maybe I'll downgrade...
    Thanks for any suggestions or help you guys can offer!
    -Mike
    Points: 2,838, Level: 32
    Level completed: 59%, Points required for next Level: 62
    31 days registered250 Experience PointsYour first Group7 days registered100 Experience Points
    Community Award
    Karbon™'s Avatar
    4346
    Denver, CO
    111
    23 times
    I think you may have an issue with your phone as usually the Display takes up more usage. Go to Verizon and let them check it out as this is rather new.
    Like my post? Press Like!
    Points: 1,831, Level: 25
    Level completed: 31%, Points required for next Level: 69
    kb4ob's Avatar
    173
    South Texas
    97
    8 times
    Are you in a good coverage area. If cellular coverage is marginal it will drain your battery faster.
    Retirement, Its a tough job but someone has to do it
    Quote Originally Posted by kb4ob View Post
    Downtown LA
    BeardedNinjaGuy's Avatar
    2291
    Maryland
    82
    You may be working from an out dated roaming area list (silly, but it has helped some people). Typically the phone keeps going from 1g/2g/3g signal loops and boosting power to compensate for perceived weaker signal areas when it does not need to.
    To fix this, dial *228 and then wait for the options list and choose option 2 to update your list. You will be told of a success and then do a power off/on, and see if that helps you like it has some others.
    FMMFL's Avatar
    139
    388
    26 times
    If you're really concerned with battery life, the Incredible will most definitely NOT be the answer.
    luv2increase's Avatar
    640
    455
    51 times
    Quote Originally Posted by FMMFL View Post
    +1
    The incredible gave me worse battery life than the DX.
    -- Rooted Droid X --
    - Core i7 920 @ 4.1Ghz
    - EVGA Classified 760
    - 2 x EVGA GTX 480s in SLI
    - 6GB G.Skill 2GHz CAS 8 RAM
    - Thermaltake 1200W PSU
    - BD-RW Drive
    tstires's Avatar
    4888
    Having the exact same issue. Little to no use and phone is completely dead within 12 hours. My prior Droid would last days with the same configurations and apps.
    Points: 1,057, Level: 17
    Level completed: 57%, Points required for next Level: 43
    lunargecko's Avatar
    4015
    24
    It sounds like you may have something being downloaded/uploaded in the background. Lots of Droid owners were seeing this issue when one of the OTA updates kept downloading over and over, subsequently killing their batteries.
    As for what could be doing this, I have no idea. However, you should look into the settings of any app that does background syncing. For example, you can go into settings, then to data manager, social applications, and enable syncing over WiFi exclusively.
    Lightninrod likes this.
    Rooted Droid X (Just for WiFi tether, hehe)
    Exit14's Avatar
    7695
    31
    Angry 2 Droid battery test
    I have the same battery drain issue with my Droid X.
    We have 2 new Droid X's in our house -my battery seemed to be draining faster than the other one so I did a test over the last few nights.
    1st I compared settings on both phones -they were set exactly the same.
    My phone has 3 downloaded apps and the other one (that retains battery life longer) has about 10 downloaded apps. There weren't any downloaded apps running in either phone when I put them down to be tested.
    the test: just before bed I've charged both droids to 100% and left them with the screen off -side by side on the kitchen counter. In the morning 8-9 hours later mine is waaay down in the red -the battery drained about 90% overnight. The other Droid has been down only about 10-20%.
    I'm taking it to Verizon right after work today and having them check it out. There is definately a problem with mine holding a charge.
    UPDATE: I took the phone to a Verizon store after work today -they did a "half hour call test"and my battery died 20 miutes into the call. They gave me a new battery under the warranty -I charged it up and so far so good.
  1. Mediaserver process problem, draining battery
    Last Post: 12-10-2010, 09:50 AM
  2. Cell standby vs phone idle
    By Trash Can in forum Droid X General Discussion
    Last Post: 08-06-2010, 02:53 PM
  3. Best app to show what is draining battery most (apps, widgets, etc)
    Last Post: 08-06-2010, 02:11 PM
  4. Cell Standby
    By RebelZero in forum Droid X Help
    Last Post: 07-25-2010, 02:23 AM
  5. Cell phone Nav and route Planning
    By Growler48 in forum Droid X General Discussion
    Last Post: 07-14-2010, 06:13 PM
Cell standby droid
cell standby draining battery
cell standby droid x
droid cell standby
droid cell standby draining battery
droid x cell standby
droid x cell standby battery
what is cell standby
what is cell standby on droid
what is cell standby on the droid
