converting to Infrastructure wifi
This is a discussion on converting to Infrastructure wifi within the Droid X Help forums, part of the Droid X Discussion category; I am new to this forum and the Droid x in general so I will begin by appologizing if I asked dumb or repetitive questions. ...
Thread: converting to Infrastructure wifi
    I am new to this forum and the Droid x in general so I will begin by appologizing if I asked dumb or repetitive questions. I have a droid x running the android 2.3.3 software straight out of the box. I am trying to get my phone to connect to my Dynavin stereo running Android software as well. My understanding is Android naturally connects via adhoc wifi and I need to convert it to Infrastructure so my stereo will be able to connect. I understand I need to root it to
    be able to convert it but I have no idea how to do this...1. What do I root it to and how? 2. How do I convert it to Infrastructure (do I do this as an app?) 3. will I lose anything already on my phone by doing this? again thanks for any help...
    Anyone have anything with this?
    Points: 2,491, Level: 30
    Level completed: 28%, Points required for next Level: 109
    truckrod's Avatar
    1670
    OHIO
    173
    12 times
    First off if you want to be rooted n on GB And your phone is stock You will have to sbf flash it back to froyo and then 4zroot it n d2bootload and then do the two step method from p3droid that has root built in. And then you will have to do some work around the wifi part.And yes you will loose all text n call history but sync your contacts n you will be fine
    Rooted OClocked DROIDX Rootedthemed Bionic
  1. Is there a DX app for converting movies?
    By wrhanson1979 in forum Droid X Apps
    Last Post: 04-17-2011, 12:07 AM
  2. Converting lower res?
    By sambobber2 in forum Off-Topic Discussion
    Last Post: 03-05-2011, 10:22 PM
  3. Converting palm files into my DX?
    By MrSpeed3 in forum Droid X Help
    Last Post: 11-23-2010, 11:43 AM
  4. Converting Video Files For DX On Mac
    By SJH X in forum Droid X Audio / Video
    Last Post: 10-19-2010, 09:36 AM
  5. Converting videos...
    By Gangsta4evr in forum Droid X Audio / Video
    Last Post: 09-25-2010, 11:43 PM
ad hoc netz umwanden in infrastructure
ad hoc to infrastructure converter
ad-hoc to infrastructure converter
cell phone convert adhoc infrastructure
convert ad hoc to infrastructure
convert ad-hoc to infrastructure
how to canvert ad hoc to infrasture wifi
how to convert ad hoc to infrastructure
how to convert ad-hoc to infrastructure
how to convert from ad hoc to infrustructure
