Droid X is perminantly bricked!
This is a discussion on Droid X is perminantly bricked! within the Droid X Help forums, part of the Droid X Discussion category; Hello everyone, today I've run into something that I have never encountered either on the fourm(s) or in my personal experience with my droid x ...
Closed Thread
Thread: Droid X is perminantly bricked!
    Points: 1,312, Level: 20
    Tagger Second Class3 months registered100 Experience Points31 days registered7 days registered
    Guncross's Avatar
    30295
    25
    Hello everyone, today I've run into something that I have never encountered either on the fourm(s) or in my personal experience with my droid x until now.
    I really need help!
    So it starts off with my phone not waking from sleep mode. I couldn't get it to respond so I did a battery pull, and it went into the M bootloop.
    At this point I was like ok fine, I'll just SBF since I wanted to try out GB anyway. So I go to do the SBF, and every time I tried to SBF, It would stop at
    erasing flash memory, then after quite a few minutes state the flashing failed.
    After several attempts I decide to try a full factory reset (hard reset).
    But guess what? I can't. When I boot into the factory reset thingy it immediately states
    E:Can't mount CACHE:recovery/command!
    Can't read MISC!
    (some other stuff I can't remember)
    (I/O error)
    (more stuff I can't remember)
    I try to factory reset regardless...
    It just loops in Wiping data:formatting data.........................(lots of dots)
    I try the other option below wipe something and it does the same thing.
    I try applying update.zip and it says it can't verify the signature!
    Soooo is my X screwed? I have no idea what caused this.
    Rooted with z4Root, running Rubix 2.01 and some black theme or something I can't remember.
    HELLLPPP! I don't know what to do here. I spent about 8 hours searching online for a fix
    Moderator
    Points: 25,450, Level: 96
    mikeinrichmond's Avatar
    9010
    Richmond, Va
    7,750
    421 times
    How did you try to SBF? What method and which file? You are going to need a well charged battery for this, so if your is dead after all the things you have tried, get it charged first. With the power off, plug the phone into an outlet. Does the charging symbol appear? If so that is a good sign, let it charge. If not, you'll need to either borrow a battery from a fellow X-er or goto VZW and have them charge it..
    Here is the easiest way to SBF:
    http://www.droidxforums.com/forum/dr...tml#post267721
    Droid X Forums Guidelines of Conduct
    Points: 6,119, Level: 50
    Level completed: 85%, Points required for next Level: 31
    Overall activity: 2.7%
    fc127's Avatar
    27223
    Cortland, NY
    1,173
    36 times
    Just posted in your other thread...
    From CM7 on my DX
    Root .602 & .605 info here.
    Need to SBF? Try this.
    DROOOID Notification Sound
    Gingerbread Red "M" Boot Logo
    Froyo White "M" Boot Logo
    100 Experience Points3 months registered31 days registered7 days registered
    dirtylaundry9's Avatar
    31350
    Check the md5 signatures of your sbf file and your update.zip, your files may have become corrupted
    Moderator
    9010
    Richmond, Va
    7,750
    421 times
    Please do not cross post. I'll leave the other one up. This one is closed.
    http://www.droidxforums.com/forum/dr...tml#post345234
Closed Thread
  1. Droid X bricked a little help?!
    By Danman96 in forum Droid X Rescue Squad
    Last Post: 05-10-2011, 08:59 PM
  2. Droid x bricked. I think.
    By Pheonixone in forum Droid X Help
    Last Post: 04-08-2011, 09:21 PM
  3. Droid X Bricked?
    By Clif in forum Droid X Rescue Squad
    Last Post: 03-20-2011, 09:03 AM
  4. Bricked My Droid X
    By StR82Sn0W in forum Droid X Rooted Issues
    Last Post: 03-19-2011, 06:06 AM
  5. Bricked my Droid X the other day.
    By Eleigh in forum Droid X Help
    Last Post: 02-14-2011, 01:28 AM
Droid charge bricked
bricked droid x
bricked droid x help
bricking & droid x
bricking a droid
bricking droidx
droid x bricked
droid x cant be bricked
droid x stock recovery cant mount cache
e: can't mount/cache/recovery/command incredible
help I bricked my droid X
signs of a bricked android
signs of bricked charge
unbrick droid x from cmd
what is bricking a droid
