How do I remove my security PIN?
This is a discussion on How do I remove my security PIN? within the Droid X Help forums, part of the Droid X Discussion category; No problem changing my PIN through settings/location & security/change screen lock : "Change or disable pattern, PIN or password" But the option for NONE (I ...
Thread: How do I remove my security PIN?
    apergaki's Avatar
    13006
    No problem changing my PIN through settings/location & security/change screen lock: "Change or disable pattern, PIN or password"
    But the option for NONE (I assume this means no PIN) is grayed out "Disabled by remote phone administrator." Also the option for a Pattern instead of a PIN is grayed out. So I can change my PIN, but how the heck do I remove it all together?
    I want to be able to use the slider lock only, without having to enter a PIN every time I put my phone down for 5 minutes. When I first got the phone I used it with no PIN for weeks, so it's possible... -Technically Challenged Old Man
    Points: 6,192, Level: 51
    Overall activity: 0.7%
    spodoc's Avatar
    17924
    2,040
    88 times
    Are you on exchange?
    spodoc's Avatar
    17924
    2,040
    88 times
    The things you speak of occur when the phone is synced to an exchange email server. Most exchange servers require pin lock. Even if you remove the account your phone is still locked up. I don't know of a way to undo this outside of a factory reset.
    spodoc's Avatar
    17924
    2,040
    88 times
    If you wish to remain synced to an exchange server but do not want the forced pin lock you will have to run a custom rom. Liberty 1.5 or 2.0.1 block this. So does Apex 1.4.
  1. Help! I cant remove Lookout Mobile Security
    By dAi in forum Droid X Rescue Squad
    Last Post: 08-07-2012, 09:52 AM
  2. New security app
    By gunner1982 in forum Droid X Apps
    Last Post: 05-28-2011, 04:08 AM
  3. Security App Out There???
    By gudziel1482 in forum Droid X Apps
    Last Post: 10-06-2010, 02:37 PM
  4. security ?'s
    By CRUCH9 in forum Droid X Help
    Last Post: 09-13-2010, 09:42 AM
  5. Replies: 7
    Last Post: 07-16-2010, 07:55 PM
android remove pin
droid mini screen lock none grayed out
how do i delete my pin from my nexus 7
how do i get the pin number taken off of my fire hd tablets
how do i remove a pin from my samsung tablet
how do you remove a pin number on a kindle fire
how to get ride of my pin number on my kindle
how to remove a pin from an android phone
remove pin code android
remove security code from android
