Google Navigation Voice
This is a discussion on Google Navigation Voice within the Droid X Help forums, part of the Droid X Discussion category; My google voice navigation works fine, except when I get in my car. My phone is paired to bluetooth and phone calls and music/audio work ...
Thread: Google Navigation Voice
    mschneid's Avatar
    4573
    My google voice navigation works fine, except when I get in my car. My phone is paired to bluetooth and phone calls and music/audio work fine. It's only the navigation voice that does not work. If I have the bluetooth on while navigation is on, music will play. A bluetooth issue? Known bug? Frustrating, as its the one spot where I need the voice! Hopefully I'm just missing something small here, hopefully someone can shed some light on this.
    Thanks.
    heycow's Avatar
    622
    Bay Area, CA
    92
    14 times
    What happens when you turn bluetooth off? Do you hear the voice through the phone speaker? Also, with Navigation there is a separate volume control for the voice. While you're on a route push the volume up button a couple times and see if that helps.
    mschneid's Avatar
    4573
    Yeah, I was aware of the separate volume and the navigation volume was at max. I don't know what happens if I turn the blue tooth off, I am going to try that next time I get in the car. But I was thinking, if that is the reason, why should I have to turn the blue tooth off just to hear the voice ...
    I will post back once I try with bluetooth disabled.
  1. google voice q
    By medicscott in forum Droid X Apps
    Last Post: 07-31-2010, 05:35 PM
  2. Google Navigation Volume Control
    By floydiannyc in forum Droid X Help
    Last Post: 07-22-2010, 06:05 PM
  3. Google Voice using a lot of data
    Last Post: 07-22-2010, 03:08 PM
  4. Google Voice problem
    By sherm in forum Droid X Help
    Last Post: 07-21-2010, 10:25 PM
  5. Setting up google voice
    By bigtmonee in forum Droid X Help
    Last Post: 07-16-2010, 03:00 PM
Droid navigation bluetooth
Droid x navigation voice
Droid x navigation voice change
droid navigation voice not working
google navigation change voice
google navigation voice
google navigation voice not working
google navigator voice
google sesli navigasyon
voices for droid X navigation
