ota on a rooted x
This is a discussion on ota on a rooted x within the Droid X Help forums, part of the Droid X Discussion category; i have a rooted x with overclocking. i got the ota the other day and it failed. curious what i need to do to get ...
Results 1 to 6 of 6
Thread: ota on a rooted x
    titans1's Avatar
    39596
    ota on a rooted x
    i have a rooted x with overclocking. i got the ota the other day and it failed. curious what i need to do to get the ota to work. i tried to unroot but that didnt work. i used Z4 root. i also have changed alot of apk files to bak. do i have to switch them all back to apk unroot and then do factory reset? or can i just unroot and do factory reset then do the ota then reroot?
    Points: 35,547, Level: 100
    Overall activity: 42.3%
    1KDS's Avatar
    3981
    6,904
    572 times
    Rename everything back to .apk and try it again. When it starts to install hit the search key, it will tell you where it failed
    Points: 8,559, Level: 62
    Level completed: 37%, Points required for next Level: 191
    Nerdslogic's Avatar
    37837
    Cybertron
    1,309
    62 times
    Quote Originally Posted by 1KDS View Post
    Interesting.....I didn't know about the search key thing
    OP.....if it gets too frusterating just SBF using 1KDS's http://www.droidxforums.com/forum/dr...-problems.html You will be good to go after that for sure.
    I have done a lot of write up's....here's a link to some. If you would like help with your phone simply ask, PM me, or drop me an email and I will assist where I can.
    List of phones I can help with: Droid, Droid 2, Droid 2 Global, Droid X, Droid X2, Droid 3, Droid Bionic.
    If you don't get response here try me on DroidForums, XDA, or Rootzwiki under the same name
    Points: 57,711, Level: 100
    Overall activity: 20.9%
    HarleyDude's Avatar
    19213
    Philly area
    7,926
    304 times
    Quote Originally Posted by titans1 View Post
    ...then do the ota then reroot?
    If you do take the OTA, you will not be able to root. If you want rooted GB.596. you must download a pre-rooted version and install.
    Official DX Gingerbread 2.3.3 (4.5.596) Release Thread - Something for everyone
    jerofld's Avatar
    34284
    325
    I recommend what HarleyDude suggested. You get to the same point, maintain root, and can easily reinstall whatever you need to get back to being OC'd. Remember to download Busybox and reinstall after updating to .596. If you use Droid X Overclock, it'll prompt you to do it, anyways.
    titans1's Avatar
    39596
    Excellent help guys ty! I decided insted to just run freedom. Very smooth and fast with oclicking it really flys and its smooth.
  1. .595 rooted
    By mpowell in forum Gingerbread Development and Hacking
    Last Post: 05-14-2011, 10:07 AM
  2. Updating to Rooted GB from Rooted Stock 2.2.1
    By Quagmire in forum Gingerbread General Discussion
    Last Post: 04-18-2011, 07:45 PM
  3. Rooted but does it cause this?
    By mrtubz69 in forum Hacking Help
    Last Post: 04-03-2011, 09:36 PM
  4. Im rooted now what?
    By AndroidGuyIsMe in forum Droid X Hacks
    Last Post: 03-25-2011, 08:55 AM
  5. Rooted X?
    By b_lengeling in forum Droid X Hacks
    Last Post: 01-26-2011, 08:29 PM
