DX Bootstrap recovery updated for Gingerbread?
This is a discussion on DX Bootstrap recovery updated for Gingerbread? within the Droid X Help forums, part of the Droid X Discussion category; Does anyone know if there is going to be an update for Koush's DX bootstrap recovery that works on Droid-X with Gingerbread? If not, is ...
Results 1 to 6 of 6
Thread: DX Bootstrap recovery updated for Gingerbread?
    Points: 449, Level: 8
    Level completed: 98%, Points required for next Level: 1
    Overall activity: 0.0%
    3 months registered100 Experience Points31 days registered7 days registeredTagger Second Class
    falk0069's Avatar
    38936
    Does anyone know if there is going to be an update for Koush's DX bootstrap recovery that works on Droid-X with Gingerbread? If not, is the D2 version fully compatible with the DX with Gingerbread?
    I'd like to be able to make backups (and restore backups). If the D2 version can do this, then that is good enough for me.
    The other question is if the D2 version works, then why was a DX version created? There must be certain features that just won't work, but does anyone know?
    Thanks
    Points: 3,256, Level: 35
    Level completed: 38%, Points required for next Level: 94
    Overall activity: 17.3%
    swalker's Avatar
    14966
    648
    16 times
    If you already have dx version it will work if you turn of debugging in development
    If not already bought then just buy d2 so you have no worries
    Points: 6,333, Level: 51
    Level completed: 92%, Points required for next Level: 17
    Sefirosu's Avatar
    28086
    Boston, Ma
    565
    The D2 version works just fine. Not sure why the X version won't work with GB. Just use D2, it works the same as X. I think the X version was just for froyo and won't work on GB.
    Points: 2,553, Level: 30
    Level completed: 69%, Points required for next Level: 47
    tgyberg's Avatar
    25707
    Minneapolis, MN
    401
    11 times
    I have used the DX version for everything. Just have to have the debugging off.
    [SIGPIC][/SIGPIC]
    Sefirosu's Avatar
    28086
    Boston, Ma
    565
    Quote Originally Posted by tgyberg View Post
    Cool. I wasn't aware of that.
    falk0069's Avatar
    38936
    Thanks everyone. I guess I'll just keep using the D2 version since I like to keep USB debugging on in order for Titanium backup to work properly. Currently I have both installed, but I've only pressed the bootstrap and reboot recovery buttons with the D2 version. If I were to run the DX version with USB debugging enabled would it just not work--both buttons? Or would I mess up the bootloading and not be able to do anything? I just don't want to mess something up the next time I need to get in clockworkmod recovery to fix my phone or to install a new rom.
  1. [HOW TO] Install and Remove Bootstrap Recovery
    By Abe21599 in forum Droid X RS Guides
    Last Post: 11-15-2014, 09:52 AM
  2. Reboot into Bootstrap recovery
    By scubamikejax904 in forum Gingerbread Help
    Last Post: 04-27-2011, 02:28 PM
  3. Help with non functional bootstrap recovery!!! Please!!
    By ibrooks123 in forum Droid X ROMs
    Last Post: 04-11-2011, 11:33 PM
  4. DX bootstrap recovery
    By jmartinez748 in forum Droid X Help
    Last Post: 04-04-2011, 05:16 AM
  5. DX Bootstrap Recovery documentation??
    By bobthebob in forum Droid X Help
    Last Post: 11-03-2010, 03:03 PM
Droid X Recovery Bootstrap
bootstrap droid x gingerbread
bootstrap recovery
bootstrap recovery droid x
droid x bootstrap gingerbread
droid x bootstrap recovery
droid x bootstrap recovery gingerbread
droid x gingerbread bootstrap
dx bootstrap
dx bootstrap download
