Sd card problem
This is a discussion on Sd card problem within the Droid X Help forums, part of the Droid X Discussion category; I am on a stock phone and my phone just rebooted and now says Sd card blank or has unsupported file system. What can i ...
Thread: Sd card problem
    Points: 1,773, Level: 24
    Level completed: 73%, Points required for next Level: 27
    500 Experience Points250 Experience Points31 days registered7 days registered100 Experience Points
    SierraRR's Avatar
    29144
    Grand Forks ND
    239
    Sd card problem
    I am on a stock phone and my phone just rebooted and now says Sd card blank or has unsupported file system. What can i do to save the stuff on my card?
    SierraRR
    DroidX
    Themer
    Points: 44,019, Level: 100
    Overall activity: 8.8%
    Downloads
    Wulf's Avatar
    33106
    2,435
    77 times
    Try and unmount and then mount sd card again see if that works. If not do a battery pull and boot up and hopefully that works, almost sounds like sd card might be corrupted.
    Themer
    Downloads
    Wulf's Avatar
    33106
    2,435
    77 times
    Also connect to pc and see if it recognizes the card. If it can't then it could be corrupt.
    SierraRR's Avatar
    29144
    Grand Forks ND
    239
    Quote Originally Posted by Wulf View Post
    Did that a couple times and still nothing. Will try it again.
    SierraRR
    DroidX
    SierraRR's Avatar
    29144
    Grand Forks ND
    239
    Haven't tried that yet.
    SierraRR
    DroidX
  1. HELP!! Sd card problem!
    By mapileTree in forum Droid X ROMs
    Last Post: 07-30-2011, 11:47 AM
  2. problem with SD Card
    By Grizzly in forum Everything about Gingerbread
    Last Post: 05-02-2011, 07:44 PM
  3. Problem with SD card.
    By jordanfleming in forum Droid X Help
    Last Post: 02-08-2011, 01:32 PM
  4. Problem with media dock and SD card
    By Tony.oe in forum Droid X Help
    Last Post: 09-30-2010, 04:07 PM
  5. Problem with my sd card
    By PorcPuffer in forum Droid X Help
    Last Post: 07-18-2010, 01:21 PM
blank sd card droid x error
droid x gingerbread blank sd
droid x gingerbread sd card problems
droid x says sd card blank
droid x says that sd card blank or has unsupported filesystem
droid x sd card blank
droidx dock unmount problem
my sd says blank oe ha unsupported files
sd card blank or has unsupported filesystem galaxy s2
sd card blank or has unsupported filesystem on droid x
