Slow and Delayed Dialer on Droid X
This is a discussion on Slow and Delayed Dialer on Droid X within the Droid X Help forums, part of the Droid X Discussion category; I already have Go Launcher installed. I'll make the switch and see if I notice a difference....
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Slow and Delayed Dialer on Droid X
    Points: 1,134, Level: 18
    Level completed: 34%, Points required for next Level: 66
    mharmon's Avatar
    24430
    27
    Points: 1,189, Level: 18
    Level completed: 89%, Points required for next Level: 11
    cmurf70's Avatar
    16998
    57
    I still don't understand why not use a task killer. I've been using atk since day one. I removed when I read here that we shouldn't use them and my phone was noticeably laggy. So I put it back on. What kind of problems are they supposed to cause, because my phone runs like a top? As long as you exclude important apps what does it hurt? I know for a fact that it has had no adverse affect on my rooted x and improves performance.
    Points: 1,448, Level: 21
    Level completed: 48%, Points required for next Level: 52
    Rsmin's Avatar
    20377
    136
    Quote Originally Posted by mharmon View Post
    I noticed my dialer slowed down after I started using go Launcher but not sure that is the problem. Let us know if it is any better when not using Go Launcher.
    Points: 44, Level: 1
    Level completed: 88%, Points required for next Level: 6
    spunk0164's Avatar
    49100
    Oct 2011
    Forced stop - seems to work
    Stumbled across this thread after wanting to throw my gd'd phone out the gd'd window for the past couple of months. Droid X, not rooted, stock. Works great EXCEPT for that whole phone thing. Delays of 5 minutes between the time I attempt to dial and anything registering on the phone.
    After reading some of the comments here, I decided to go to Mange Applications under Settings. Found Dialer. Hit Force Stop. Went back to Dialer. What do you know - it detected me wanting to call someone RIGHT away. Not sure if this is a long term fix but it seems to work in this instance.
    Points: 335, Level: 6
    Level completed: 70%, Points required for next Level: 15
    jmckean's Avatar
    51682
    Nov 2011
    Still struggling with this
    I timed a 6 minute delay yesterday. Force stopping dialer helps IF it is not grayed out, which it usually is. Rebooting the phone usually DOES NOT fix the problem, which I find puzzling.
    Using CarDock seems to initiate the problem on my phone, but my wife's DX has the same problem and she never uses CarDock. Also I have Launcher Pro and she is using the native launcher.
    Neither phone is rooted. Both have the latest OTA updates
    I have no task killer apps installed. My wife did but removed it. I cannot tell a difference.
  1. slow running droid X
    By big.daddy in forum Droid X General Discussion
    Last Post: 12-31-2010, 08:21 PM
  2. Droid X 3G really slow?
    By budmonster in forum Droid X Help
    Last Post: 11-23-2010, 08:45 PM
  3. sense ui dialer-predictive dialer
    By pelzinga in forum Droid X Help
    Last Post: 09-02-2010, 11:34 AM
  4. Replies: 56
    Last Post: 08-20-2010, 01:07 AM
  5. Droid X...slow slow slow for me. NEEED HELP!!
    By DrroidX in forum Droid X General Discussion
    Last Post: 08-10-2010, 01:09 PM
android phone slow to dial
android phone slow to make calls
droid x delayed calling
droid x dialer slow
droid x slow to dial
droid x2 call delay
droid x2 delayed dialing
droid x2 slow dialing
droid x2 slow to make calls
slow dialer response on moto g
