Help me prepare my rooted DroidX for the gingerbread update....
This is a discussion on Help me prepare my rooted DroidX for the gingerbread update.... within the Droid X Help forums, part of the Droid X Discussion category; so, i have a rooted droid x...i removed bloatware and some other stuff i didnt want. what do i need to do so when the ...
Results 1 to 9 of 9
Thread: Help me prepare my rooted DroidX for the gingerbread update....
    Points: 1,015, Level: 17
    Level completed: 15%, Points required for next Level: 85
    Jeph's Avatar
    36646
    27
    so, i have a rooted droid x...i removed bloatware and some other stuff i didnt want. what do i need to do so when the update is released, ill be able to safely get it?
    i assume need to flash my sbf back to stock??...could someone maybe direct me to the download and directions on how to do that??
    thanks!!
    system verzion 2.3.240 mv810.verizon.en.us
    droid x
    android version2.2.1
    Moderator
    Points: 25,450, Level: 96
    mikeinrichmond's Avatar
    9010
    Richmond, Va
    7,750
    421 times
    This is the easiest way to SBF back to stock so you can take the OTA:
    http://www.droidxforums.com/forum/dr...tml#post267721
    Go ahead and make the cd or USB and test it out to the point that you get the choice to pick #1 (bootloader) or #2 (not ready)...Just don't bother to connect the phone, once you can get it to that point, you will know it will work when the time comes..
    Droid X Forums Guidelines of Conduct
    Jeph's Avatar
    36646
    27
    i have rds lite and flashed once before using that....it worked well, i just forgot how to do it and i dont have the SBF file anymore. any instructions on how to do it using that method?
    Points: 1,248, Level: 19
    Level completed: 48%, Points required for next Level: 52
    Psychosis's Avatar
    14464
    32
    You said you removed bloatware. Did you really remove it or did you freeze it or rename it. If you removed it you will need to sbf but if you didn't you can just rename back or unfreeze without sbfing. You should then be ready. You can take the ota while rooted, it will just remove root usually when it updates.
    If I am wrong someone please correct me.
    Points: 26,306, Level: 96
    Level completed: 96%, Points required for next Level: 44
    MICHO's Avatar
    30057
    behind a dumpster
    4,605
    99 times
    Just go to the link that Mike posted all instructions and how to's are there
    Yesterday is history, tomorrow is a mystery, and today is a gift; that's why they call it the present. -Eleanor Roosevelt
    MICHO's Avatar
    30057
    behind a dumpster
    4,605
    99 times
    Quote Originally Posted by Psychosis View Post
    No need to correct your on the money!
    Jeph's Avatar
    36646
    27
    i did erase them, i probably should have froze them but i am kinda new that this.
    MICHO's Avatar
    30057
    behind a dumpster
    4,605
    99 times
    Well the easy way to sbf is that link.
    Jeph's Avatar
    36646
    27
    thanks! just flashed. worked perfect. i was nervous cause the instructions said it might enter a boot loop and boot loops scare me cause i think i broke my phone. but it didnt even boot loop...just turned on all fresh and new.
    so i guess im ready for gingerbread on friday!
  1. Gingerbread droidx rooted
    By Hulk0069 in forum Gingerbread General Discussion
    Last Post: 04-26-2011, 03:17 PM
  2. How to prepare for upcomming verizon ota update?
    By classact in forum Gingerbread General Discussion
    Last Post: 04-11-2011, 09:20 AM
  3. Motorola Droid X'ers - Prepare for Update!
    By danDroid in forum Droid X News
    Last Post: 12-13-2010, 03:31 PM
  4. What will we need to do to prepare for Droid X update?
    By royolpunk in forum Droid X General Discussion
    Last Post: 12-13-2010, 12:06 PM
  5. Replies: 6
    Last Post: 10-30-2010, 12:47 PM
droid x gingerbread update on rooted phone
droid x update for rooted phone
droid x update on rooted phone
droid x update root
droid x update rooted phone
how do i update my rooted droid x
how to update a rooted droid x
how to update rooted droid x
what to do with rooted droid x
