Roadrunner Outgoing Mail
This is a discussion on Roadrunner Outgoing Mail within the Droid X Help forums, part of the Droid X Discussion category; I did a search on this here and other places and I did see wherebsome people have had success using mobile-server.roadrunner.com. The problem is that ...
Results 1 to 10 of 10
Thread: Roadrunner Outgoing Mail
    Points: 816, Level: 15
    ellymae's Avatar
    35521
    17
    I did a search on this here and other places and I did see wherebsome people have had success using mobile-server.roadrunner.com. The problem is that my regular outgoing server doesn't say roadrunner at all. It's smtp-server.carolina.rr.com. I am still unable to send mail but receive it fine. Anyone know of a fix for me? Thanks!
    Points: 912, Level: 16
    pool_shark's Avatar
    31799
    Ohio
    202
    From what I understand not all areas for roadrunner are set to allow outgoing emails from their servers without being on their ISP.
    Mine works, my outgoing server is smtp-server.roadrunner.com
    ellymae's Avatar
    35521
    17
    Finally got it. The one thing I didn't try was changing the port. Changed it to 587 and it worked immediately.
    Points: 1,031, Level: 17
    Level completed: 31%, Points required for next Level: 69
    JtheDroid's Avatar
    38993
    I'm experiencing the same problem and this information from Road Runner Help did not fix my problem. They indicate the outgoing mail should be sent via mobile-smtp.roadrunner.com using Port 25. The link is for Help for Eastern Carolina (ec.rr.com) accounts.
    To send Road Runner Web Mail from your Android phone:
    1. On your Android select Settings.
    2. Select Accounts.
    3. Select Add Account (or select existing Road Runner Email address if it has already been set up).
    4. Select Email.
    5. In the General Settings window fill out your:
      • Name
      • Email Address: yourusername@ec.rr.com
      • Password
      • Description: Road Runner Email address (Name that displays in your Account list on the Android)
    6. Select Next.
    7. Select POP and fill out the Incoming Mail Server and Outgoing Mail Server form:
        • Incoming Mail Server Host: pop-server.ec.rr.com
        • If needed, enter port 110 and set Secure Server to off
        • Outgoing Mail ServerHost: mobile-smtp.roadrunner.com
        • If needed, enter port 25 and set Secure Server to off
      • Select Ok.
    Road Runner Help | Road Runner Web Mail - Android Email Settings
    JtheDroid's Avatar
    38993
    For what it's worth, after trying all of the 'fixes' I've read about here and on the Web, I removed my Road Runner account and set it up again (using the servers in my post above), the Road Runner mail works again.
    Of course, this doesn't fix the problem with other email accounts I have setup on the Droid X, guess the 'fix' is to remove them and set them up again.
    This is not the first time I've experienced this problem or had to perform the remove/add account 'fix', anxiously awaiting my invitation to update the OS.
    Advocate X Achievements:
    The persuader's Avatar
    12986
    Maine
    5,603
    66 times
    What I experienced with Roadrunner is...
    I receive my Emails to my phone but cannot view the Emails...However that said...If I go to my Apex Toolbox and change from AOSP to BLUR...I get the Red Mailbox which shows both acccounts...I find it to be very Dicey with Emails...Most of the time it doesnt work...So I decided to stay with AOSP for now...I deleted my Roadrunner account from my Phone and just access from my laptop...
    Pain in the *ss but its not my Primary Email account
    "Stubborn In You're Bones"
    cineman's Avatar
    41742
    After being told everything under the sun from Time Warner why I cannot send email from my Droid X using my Roadrunner account, I finally found two settings that are working (one for wi-fi connection, one for 3G):
    Tested on Droid X and Droid 2:
    To send e-mail on my Southern California Roadrunner account via 3G:
    1) Username is your full e-mail address i.e.: yourname@roadrunner.com
    2) Change Outgoing port from 25 to 587
    3) SMTP server: smtp-server.roadrunner.com
    4) Do not check "use secure server"
    5) Select "auto" for use secure password
    6) Select "auto" for authentication
    7) Do not check "verify certificate"
    To send e-mail on my Southern California Roadrunner account via Wi-Fi:
    Everything is the same except line #6, change it to NONE
    Now, I did not have authentication options on my Droid X until I did the system upgrade to 2.3.3 but my other phone (Droid 2) did offer these options with 2.2.1
    Your incoming settings are the standard port 110, username (not full address), pop-server.roadrunner.com, do not check "secure connection", use auto for secure password, authentication is "password" do not verify certificate.
    Don't know if this will work for everyone else, but nothing else worked for me in SoCal. Good luck!
    Points: 51,689, Level: 100
    Overall activity: 99.9%
    fezrock's Avatar
    29044
    Asheville-ish
    10,465
    573 times
    Glad you persevered! I gave up on isp email awhile ago. Got tired of having to change accounts and such when I dropped a telecom for another.
    -DX
    Thank you! Thank you! Thank you!
    Thank you so much for your information!!!
    Quote Originally Posted by cineman View Post
    I have just spent a full day on the phone and chat with both roadrunner and Verizon technical suport. I had no resolution to sending e-mail on rr account only. I tried every setting possible and finally stumbled on the combination that let me send e-mail from central New York Roadrunner: Outgoing Server:
    mobil-smpt.roadrunner.com
    username: XXXXX@twcny.rr.com
    Password: xxxxx
    Port: 587
    Do NOT check: Use secure connection or Verify Certificate
    Use secure password (TLS): AUTO
    Authentication: AUTO
    I would think roadrunner technical support to focus in on your location and immediately give you the proper set up for Droid! Don't know why the problem, but I guess it's just laborious trial and error!!! Thanks.
  1. Outgoing e-mail issues
    By Korsea in forum Droid X Help
    Last Post: 04-29-2011, 07:08 AM
  2. 1and1 webmail Droid X problem with outgoing mail
    By grizzlywj in forum Droid X Help
    Last Post: 01-05-2011, 09:25 AM
  3. Roadrunner web mail
    By oz7322 in forum Droid X Help
    Last Post: 10-15-2010, 01:47 AM
  4. No outgoing e-mail with Godaddy...Please help
    By Bill Nichols in forum Droid X Help
    Last Post: 08-12-2010, 06:47 AM
  5. DROID X - Roadrunner Email
    Last Post: 07-15-2010, 01:34 AM
ec.rr.com email port settings
kindle fire hd cannot send email roadrunner
problems with roadrunner email on kindle
roadrunner - outgoing cell phone settings
roadrunner business class email settings
roadrunner email settings for kindle fire
set up roadrunner email on kindle
setting up twcny email on kindle fire
time warner cable outlook settings for outgoing mail on kindle fire
wi.rr incoming email port
