dropped my phone in water
This is a discussion on dropped my phone in water within the Droid X Help forums, part of the Droid X Discussion category; i dropped my phone in water, and cant get it to turn back on..... any suggestions?...
Results 1 to 10 of 19
Thread: dropped my phone in water
    Points: 7,208, Level: 56
    500 Experience Points250 Experience PointsCreated Album picturesThree Friends100 Experience Points
    didiwags's Avatar
    55
    Minnesota
    1,450
    21 times
    Get a new phone!!! Once water hits aphone your pretty much screwed!!! Do u have insurance?
    Droid Does!!!
    7 days registered100 Experience Points
    Champin4's Avatar
    345
    44
    DONT TRY TO TURN IT ON!
    stick it in a container of rice for at least a full day or two, then try. If it doesn't turn on then you're out of luck :/
    Points: 6,605, Level: 53
    Level completed: 28%, Points required for next Level: 145
    250 Experience PointsThree FriendsCreated Album picturesYour first Group100 Experience Points
    Calendar Award
    yurdle's Avatar
    78
    In a land with pretty pink elephants =) Oh wait.. do people see this?
    513
    25 times
    Have yet to figure out why turning on the phone is te first thing people try to do after dropping it in water...
    Not sure if this guy did but i know alot of people do...
    Do as is said above... this has saved a few of my friends... i've luckely never had water damage
    Leave phone off... pull he battery and put both battery and phone with back cover off into a bag of rice.
    Droid X
    Gingerbread
    Stock - Rooted - Deodexed
    Xoom(Gold Oscar Edition)
    Honeycomb 3.1
    Stock
    irod87's Avatar
    3162
    Texas
    115
    do the rice thing and hope for the best.
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    Quote Originally Posted by Champin4 View Post
    Good advice...
    Also check the "water damage indicator"...if red, your phone is most likely gone.
    Points: 4,469, Level: 42
    Level completed: 60%, Points required for next Level: 81
    BOWIE's Avatar
    1078
    Scottsdale, AZ
    603
    39 times
    Most electrical componnts can handle getting wet. It's when you provide electricity (IE; turning on your phone) that the problems start, because the water provides a way for the electricity to travel into places where it can cause damage. Being that you have already tried to turn it on, it's likely a loss. If you don't have insurance on the phone, try drying it out. Some recommend rice but an anti-humectant like silica beads (found at a craft store for drying flowers or at a gun shop for preventing rust) is far more effective than rice.
    Points: 1,681, Level: 23
    Level completed: 81%, Points required for next Level: 19
    250 Experience Points31 days registered100 Experience PointsTagger Second Class7 days registered
    sherylhs's Avatar
    783
    Michigan
    34
    I dropped my D1 in the ocean in the middle of May. I immediately shut it off and pulled the battery. I then put it in rice for about 24 hours. I turned it on a couple of times to see if it was working in that 24 hour period. My touch screen was acting haunted. I went and bought another phone. About a week after I got home from vacation, I was curious so I turned the phone on... worked like a charm. Returned the new phone, activated my ocean phone and it pretty much worked like a charm until I purchased my DX. I only had two issues with it when the humidity was really high, but a few minutes by the air conditioning vent and it was back to normal.
    Here's the link to my post about it over on the Droid forums...
    Wet Droid with a happy ending (so far) - Droid Forum - Verizon Droid & the Motorola Droid Forum
    Good luck!
    well what i did was, picked my phone up out of the water left it on and the screen started acting funny so i turned it off. i wont turn back on. the water damage indicated says its good. yes i have insurance. and this happened on sat. is it to late to do the rice thing?
    Agent X Achievements:
    Asharad's Avatar
    294
    Tiamat
    1,100
    25 times
    Can't hurt to try. Pull the battery pronto.
  1. Replies: 21
    Last Post: 08-29-2010, 01:07 PM
  2. Phone contacts don't show up in the phone
    By bobgoodfellow in forum Droid X Help
    Last Post: 07-28-2010, 03:33 PM
I dropped my droid in water
droid dropped in water
droid mini dropped in water
droid phone dropped in water
droid x dropped in water
dropped droid in water
dropped droid x in water
dropped my droid x in water
moto x dropped in water
