Droid x constantly ringing!
This is a discussion on Droid x constantly ringing! within the Droid X Help forums, part of the Droid X Discussion category; My droid x is constantly ringing. It is coming from the speaker where you put your ear, I can get a text and it rings ...
Results 1 to 8 of 8
Thread: Droid x constantly ringing!
    My droid x is constantly ringing. It is coming from the speaker where you put your ear, I can get a text and it rings "DROIIDDD" but keeps ringing. I can have someone call me, and it still rings, and rings while I am in the call. Its a ringing of like a older phone. It will ring for about 3 seconds, stop for about 5 then ring again. Does ANYONE have a solution for this?
    mandog202's Avatar
    25661
    Huntsville AL
    261
    20 times
    is the alarm clock going off?
    Sent from my Xoom using Tapatalk
    no its not that alarm. all my alarms are set for like 8 hours from now. It has done it before. The only way to stop it is to power it off but even while its powering off it still rings. Its also a faint ringing.
    RS Team Leader
    Points: 25,439, Level: 96
    Level completed: 9%, Points required for next Level: 911
    Overall activity: 15.1%
    popcenator's Avatar
    21238
    Omaha, NE
    8,255
    177 times
    Sounds like a hardware issue, I'd take it to Verizon.
    Points: 3,499, Level: 36
    Level completed: 99%, Points required for next Level: 1
    Overall activity: 1.3%
    AndroidScott's Avatar
    8156
    213
    8 times
    Have you tried shutting the phone and pulling the battery? Factory reset?
    Points: 103, Level: 2
    Level completed: 6%, Points required for next Level: 47
    BOY_FIX.IT's Avatar
    47419
    Sep 2011
    Yesssssssssss... I am the first person to fix this problem...plus this is my first post ever so listen up.It is a roaming/calling problem. My uncle jus came up to about 10min ago and asked can I fix it, so I checked on the internet and couldn't find the solution anywhere, I played wit the phone anddd...1. Go to setting2. Applications3. Manage Aplications4. Click Running Applicaion5. Scroll down to the app that says PHONE. Click on it and force close it. "The PHONE app will not force close but the ringing should stop.Five easy steps.
    8156
    213
    8 times
    Quote Originally Posted by BOY_FIX.IT View Post
    Have you tried using the phone since your fix? Work as normal? What happens after a shutdown and restart?
    BOY_FIX.IT's Avatar
    47419
    Sep 2011
    Quote Originally Posted by AndroidScott View Post
    Nope... as I read in another thread, its a software issue, that's the easist way I could think of. There is no such thing as completly stopping it, unless u get a new phone. Again it a roaming/calling issue and u nore your company can stop that, only the people that made the phone can (samsung, LG...ext) sorry. Oh and some phones might have the app under DAILER instead of PHONE.
  1. Texts Not Ringing?
    By trueblue7711 in forum Droid X Help
    Last Post: 09-25-2011, 09:40 AM
  2. Droid X Stop Ringing? I've got your solution.
    By thatoneguy5349 in forum Droid X Help
    Last Post: 05-17-2011, 06:14 PM
  3. Ringing when bluetooth headset connected
    By sine mora in forum Droid X Help
    Last Post: 05-08-2011, 01:22 PM
  4. Droid X constantly rebooting....Help!
    By Timbo in forum Droid X Help
    Last Post: 04-01-2011, 10:09 AM
  5. Ringing when USB plugged in
    By jcg10601 in forum Droid X Help
    Last Post: 09-04-2010, 09:23 PM
android constant ringing
droid dna constant ringing
droid dna keeps ringing
droid keeps ringing
htc dna constant ringing
htc droid dna keeps ringing
why does my droid dna keep ringing
why does my droid keep ringing
why is my android ringing
why is my droid ringing
