I downloaded Liberty to change the icons. When it didnt work after rebooting I deleted it. My internet will not work now! HELP!
This is a discussion on internet wont work now! within the Droid X Help forums, part of the Droid X Discussion category; I downloaded Liberty to change the icons. When it didnt work after rebooting I deleted it. My internet will not work now! HELP!...
Anyone????
What did you delete? Did you make a backup of your stock setup after rooting? If so, you can restore it...
