Changing songs during navigation without interrupting nav -- is this possible?
This is a discussion on Changing songs during navigation without interrupting nav -- is this possible? within the Droid X Help forums, part of the Droid X Discussion category; I run the Car Dock app, and use Navigation through it. If I then want to play some music, I go back to the main ...
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: Changing songs during navigation without interrupting nav -- is this possible?
    Points: 2,023, Level: 27
    Level completed: 16%, Points required for next Level: 127
    pastrygirl's Avatar
    874
    95
    13 times
    I run the Car Dock app, and use Navigation through it. If I then want to play some music, I go back to the main Car Dock page and start the player... then when I go back to Navigation, I have to start over. It doesn't pick up where it left off. Same thing if I want to change tracks in the middle of navigating.
    Is there a good workaround for this? I've been stumbling with QuickDesk and Power Strip, to no avail. I can't get my search button to register anything other than voice search, even with the Button Shortcut app. Double-home doesn't work with QuickDesk when I'm running Car Dock; it just registers my default double-home action. Single home works OK, but then I have trouble exiting Car Dock -- I end up in an infinite loop of Car Dock and Quick Desk. (And I lose my single-home click action, which is to pull down the hidden notification bar.)
    I looked at the Car Dock v2 app, but want my background to be black; can't figure out how to do that. My usual background is too fussy for the car and big icons.
    Help?
    pastrygirl's Avatar
    874
    95
    13 times
    Anyone?
    I managed to get Button Shortcut to use my camera button to launch QuickDesk, so that works OK... but it seems like such a clunky solution. What if I need to make a call while navigating? Would I have to restart the navigation? There must be a way to do this without needing several apps, right?
    pastrygirl's Avatar
    874
    95
    13 times
    Is this just a really dumb question...?
    Points: 71,073, Level: 100
    Overall activity: 29.7%
    20,495
    876 times
    Quote Originally Posted by pastrygirl View Post
    Not a dumb question, I'd like to know to. ;-)
    Sent from my Droid X
    Guidelines of Conduct for DroidXForums.com
    Points: 2,557, Level: 30
    Level completed: 72%, Points required for next Level: 43
    3 months registered31 days registered250 Experience Points7 days registered100 Experience Points
    nojogray's Avatar
    3383
    Annapolis, Md
    67
    Definitely not a dumb question... you just stumped us.
    nojogray's Avatar
    3383
    Annapolis, Md
    67
    I found a 90% solution. After you change the song, navigation should be tuning in the background. Poul down your notification bar and select the navigation already in progress. Let me know of that helped.
    pastrygirl's Avatar
    874
    95
    13 times
    LOL -- glad to know it's not just me!
    The current nav doesn't show up in my notification bar once I back out of nav to get to the music controls... It disappears as soon as I press the back button.
    nojogray's Avatar
    3383
    Annapolis, Md
    67
    Well, shoot. I think you are SOL
    pastrygirl's Avatar
    874
    95
    13 times
    I've been working with QuickDesk (via my camera button) and it's actually not bad. I'll stick with that until a better solution comes along.
    Thanks anyway!
    pastrygirl's Avatar
    874
    95
    13 times
    My camera button stopped working for launching QuickDesk, so I had to figure something else out. Turns out the music player shows up in the notification bar, so I can pull it down while navigating. Still kinda kludgy as it requires more attention than I care to give while driving, but it works.
    (Oh, and my camera button reassignment stopped working because I had installed Vignette.)
  1. Best GPS Navigation App
    By mth0825 in forum Droid X Apps
    Last Post: 04-03-2013, 07:27 AM
  2. changing avatar
    By boston0108 in forum New Member Introductions & Site Assistance
    Last Post: 07-23-2010, 01:03 PM
  3. can someone help me with changing voicemail notification sounds?
    By arabstar1982 in forum Droid X General Discussion
    Last Post: 07-20-2010, 11:40 PM
  4. Changing Text Size?
    By dan266 in forum Droid X Help
    Last Post: 07-20-2010, 12:51 AM
  5. Replies: 0
    Last Post: 07-16-2010, 08:17 AM
GoBack navigation already in progress
amending play list without interruping output
android change music without exiting app
android change songs in car with navigation
android navigation music controls
goback() navigation already in progress
how to change songs on droid x 2
quickdesk car mode
wp7 navigation already in progress
