I saw a video on YouTube where a guy had his all blue, with a pretty awesome theme.
He was on Liberty 1.5, so I am assuming you can do the same on 2.0.
Is this through the Liberty Toolbox app? Will I need the 5$ version if so?
This is a discussion on How do you get themes with Liberty 2.0? within the Droid X Help forums, part of the Droid X Discussion category; I saw a video on YouTube where a guy had his all blue, with a pretty awesome theme. He was on Liberty 1.5, so I ...
Droid X Running CM7
Just scored 3210 in quadrant!
I have the Liberty 2.0 toolbox and it is the free version. If you go into ROM manager, then download roms you will see a bunch of themes you can download. If you knew the name of the theme it would make it much faster
Is this just like you hit install theme and it does it on its own?
Or do you need to go through Clockwork and stuff?
Droid X Running CM7
if you download the theme, then you can either hit install when it prompts you, or you can go into clockwork. Thats how I do it. If you reboot into recovery then go Liberty > Themes > then pick your theme
Sounds good.
There was only one theme available when I did it though, I think it was Oreo something.
Droid X Running CM7
there was only one theme available to download? there was like 20 or more when I checked and that was like 2 hours ago
That's cus the drop down needs to say all
Yesterday is history, tomorrow is a mystery, and today is a gift; that's why they call it the present. -Eleanor Roosevelt
ok well you can have multiple themes and just switch back and forth
