Voice prompt for bluetooth, volume too low
This is a discussion on Voice prompt for bluetooth, volume too low within the Droid X Help forums, part of the Droid X Discussion category; I have recently developed a problem using my bluetooth with my DroidX The volume for the voice prompt stating, "say a command" is too low, ...
Thread: Voice prompt for bluetooth, volume too low
    Points: 786, Level: 14
    Level completed: 86%, Points required for next Level: 14
    Bulldogmotor's Avatar
    25812
    7
    I have recently developed a problem using my bluetooth with my DroidX The volume for the voice prompt stating, "say a command" is too low, almost non existent. The volume when talking with someone is fine. Is there anything I can do?
    Points: 1,288, Level: 19
    Level completed: 88%, Points required for next Level: 12
    pizza_pablo's Avatar
    32926
    36
    Check out this thread... "Please say a command...."
    with attn given to posts # 6 & 7.
    I have the same prob. Most likely because I almost always have sound on vibrate only.
    I got Volume Master Free, to see if that helps.
    Quote Originally Posted by Bulldogmotor View Post
    Turn off the Bluetooth on the Droid X. Place a phone call like normal. Adjust the call volume to the MAX and then hang up. Turn the Bluetooth on the Droid X back on and activate your voice command. It will work. You can adjust volume up or down in that fashion.
    32926
    36
    My 'Voice Command" volume is different from time to time. Sometimes low, sometimes descent, sometimes it comes out over the DX's external speaker, even tho the ear bud is connected and the resulting call rings thru the ear bud speaker....go figure.
    Rick's suggestion seems that it would result in really loud volume for hand held conversations. Bugs to be worked out, I guess.
  1. Voice Dialing Over Bluetooth
    By DJUnix in forum Droid X Help
    Last Post: 05-07-2011, 08:11 AM
  2. Voice to to text over bluetooth?
    By boisetrucker in forum Droid X Help
    Last Post: 02-08-2011, 03:06 PM
  3. Voice dial volume issue in cardock
    By oper8or in forum Droid X Help
    Last Post: 01-16-2011, 12:34 PM
  4. Replies: 2
    Last Post: 11-06-2010, 12:51 AM
  5. Trying to use Voice command while connected to car bluetooth...
    By jls in forum Droid X General Discussion
    Last Post: 07-19-2010, 08:21 PM
android bluetooth volume
android bluetooth volume low
android bluetooth volume too low
android voice dialer volume
bluetooth volume too low android
droid x bluetooth volume low
galaxy nexus voice dialer prompt volume fix
low bluetooth volume android
