baseband questions and help
This is a discussion on baseband questions and help within the Droid X Help forums, part of the Droid X Discussion category; Hi, I have some questions about the baseband 1) Is there any way to backup a baseband? 2) Can I extract the baseband from a ...
Thread: baseband questions and help
    Tagger Second Class100 Experience Points31 days registered7 days registered
    dmb_00's Avatar
    28178
    Question baseband questions and help
    2) Can I extract the baseband from a SBF?
    3) Does anybody have BP_C_02.02.00P baseband?
    Thankyou!
    Points: 17,929, Level: 85
    Snow02's Avatar
    22940
    3,769
    142 times
    1) Not readily.
    2) Again, not readily, but yes. I don't know how though.
    3) I don't. How old is that baseband? You almost always want to be on the newest baseband.
    dmb_00's Avatar
    28178
    Thanks for the answer. My problem is that I have a non US droid x, and my radio got unconfigured, and the SBF that I have form my carrier doesn't work because I've updated my bootloader to 30.04, so I thought may be I can extract only the baseband and use the 2.3.340 SBF like usual, and update the baseband.. I don't know if this is the right way..
    Regards
  1. I need baseband and kernel versions for stock 2.3.15
    Last Post: 04-15-2011, 02:11 PM
  2. Baseband version question
    By gunner1982 in forum Gingerbread General Discussion
    Last Post: 04-09-2011, 08:51 AM
  3. How do I get baseband BP_C_01.09.07P ???
    By ziv in forum Droid X Hacks
    Last Post: 12-14-2010, 08:38 PM
  4. Baseband 3G vs 1X on RubiX 1.6 and 1.8 vs Stock Droid X
    By movadoevo8 in forum Droid X ROMs
    Last Post: 11-22-2010, 11:30 AM
  5. Replies: 12
    Last Post: 11-13-2010, 09:38 PM
android backup baseband
backup baseband
backup baseband android
backup baseband droid x
baseband backup android
bp c 02.02.00p
droid x new radio
extract baseband from sbf
how to backup baseband
how to backup baseband android
