Launcher Pro Plus force close on start-up, otherwise fine?
This is a discussion on Launcher Pro Plus force close on start-up, otherwise fine? within the Droid X Help forums, part of the Droid X Discussion category; Like the title says, every time I reboot my phone LP fc's before it starts functioning properly. I am currently on Gingerbread rooted and deodex'd, ...
Thread: Launcher Pro Plus force close on start-up, otherwise fine?
    Points: 6,135, Level: 50
    Level completed: 93%, Points required for next Level: 15
    Overall activity: 2.6%
    500 Experience PointsCreated Album pictures250 Experience Points100 Experience Points7 days registered
    eric eakin's Avatar
    3548
    Ca
    1,071
    23 times
    Question Launcher Pro Plus force close on start-up, otherwise fine?
    Like the title says, every time I reboot my phone LP fc's before it starts functioning properly. I am currently on Gingerbread rooted and deodex'd, yet I even have this problem when i run stock froyo and everything in-between! Anyone have any ideas why this may be happening? I can not for the life of me figure it out! I have tried wiping cache, fixing permissions, wiping delvik cache, factory reset, yet it still persists. Please help if you can.
    Thanks!
    Addicted to technology but don't always get it!
    X 2
    Points: 5,955, Level: 50
    Level completed: 3%, Points required for next Level: 195
    scottpole's Avatar
    27229
    1,119
    38 times
    Have you also tried uninstalling and reinstalling.
    Yummy LibertyBread with a side of Superuser :P
    Warm Gingerbread with super user icing
    eric eakin's Avatar
    3548
    Ca
    1,071
    23 times
    i have several times on froyo, not on ginger. also totally reset my lp from scratch, but that was froyo. seemed to me its more than just an uninstall re install problem - but i could be totally wrong. have nothing else to do right now, ill try it again.
    X 2
    eric eakin's Avatar
    3548
    Ca
    1,071
    23 times
    so i un installed lpp then re installed it, rebooted my phone and it still froze up.... could it be anything to do with the process the super user items load?
    X 2
    Casen's Avatar
    12189
    264
    12 times
    Did you ever fix this issue, as I to have had it for a long while.
    Droid X: Liberty 2.0, Oreo theme!
  1. Contacts Force Close
    By hillmom in forum Droid X Hacks
    Last Post: 04-16-2011, 09:34 PM
  2. GB Force Close
    By brandonXabbott in forum Gingerbread Help
    Last Post: 04-07-2011, 09:57 AM
  3. Twitter force close
    By Sean Wristen in forum Droid X Apps
    Last Post: 02-07-2011, 11:13 PM
  4. What does Force Close mean
    By artmanphoto in forum Droid X Help
    Last Post: 12-16-2010, 08:30 PM
  5. Launcher Pro Force Close
    By MovieMan in forum Droid X Help
    Last Post: 09-23-2010, 09:12 AM
launcher pro fc startup
launcher pro force close
launcher pro force close boot
launcher pro force close on boot
launcher pro force close on startup
launcher pro force close startup
launcher pro force closes
launcher pro plus force close
launcherpro force close
launcherpro force close on boot
