Please please help me with my ringtones
This is a discussion on Please please help me with my ringtones within the Droid X Help forums, part of the Droid X Discussion category; I've been setting ringtones for personal contacts but it does not work. All of my ringtones are saved on my memory card. Please help me ...
Results 1 to 10 of 15
Thread: Please please help me with my ringtones
    Please help me figure this out!
    Thank you ; )
    jerofld's Avatar
    34284
    325
    Only thing I can think to do is to move the sounds to the root of your SD card or perhaps even to the phone itself.
    If that doesn't work, you may have to do something a bit more drastic, like factory wipe the device or take it into a verizon store and let them try to figure it out.
    Points: 1,968, Level: 26
    neOwb's Avatar
    26092
    48
    If you're rooted try moving them to system/media/audio/ringtones
    jerofld's Avatar
    34284
    325
    Oh, just remembered...
    Do you have "Caller ID Readout" set to anything but "Ring Only"? Go to Settings > Call settings > Caller ID Readout. If so, change it to "Ring Only". Caller ID Readout will do it's thing before letting ringtones play. Which, if you're quick to answer your phone, will make it so your ringtones never play.
    Points: 2,491, Level: 30
    Level completed: 28%, Points required for next Level: 109
    truckrod's Avatar
    1670
    OHIO
    173
    12 times
    Why o why would you ever go to a verizon store. There is nothing you can't do rite at home even warranty issues if need be. With help from here or other sites !! come on
    Rooted OClocked DROIDX Rootedthemed Bionic
    Points: 9,907, Level: 66
    ToeJamm57's Avatar
    6466
    Michigan
    2,463
    64 times
    If you have your phone plugged in to USB it will not read ringtones from the card and will go back to some default. Are you ringtones working when your phone is unplugged?
    truckrod's Avatar
    1670
    OHIO
    173
    12 times
    Quote Originally Posted by ToeJamm57 View Post
    Yes that is correct sometimes you have to do a reboot after a usb disconnection
    Also if you do move your ringtones to your media folder they will stay there but it does mess up after usb disconnection . this has been an ongoing problem with the X
    ToeJamm57's Avatar
    6466
    Michigan
    2,463
    64 times
    Apart from an occasional glitch my ringtones are much more stable now than they used to be. Not sure if that is because I am on the Apex ROM or some other unknown reason. Now and then the phone forgets one of my custom tones and goes to default but for the most part they stay the way they are supposed to now.
    Thank you for all the advice! My ringtones are finally working when they call. However, they don't work when pepople text me. Is thy normal????
    ToeJamm57's Avatar
    6466
    Michigan
    2,463
    64 times
    Are you using the stock messaging app or another?
  1. Ringtones
    By india11111 in forum Droid X Help
    Last Post: 04-05-2011, 06:29 PM
  2. Ringtones
    By chump in forum Droid X Help
    Last Post: 01-17-2011, 11:41 PM
  3. Using downloaded app (ringtones) as ringtones
    By kwhiteley in forum New Member Introductions & Site Assistance
    Last Post: 12-29-2010, 03:57 PM
  4. ringtones
    By kmeyer13 in forum Droid X Rescue Squad
    Last Post: 12-17-2010, 12:05 PM
  5. Ringtones
    By phimuskapsi in forum Droid X Apps
    Last Post: 08-04-2010, 12:34 PM
my ringtones
help me set my ring tone
take me to my ringtone settings
why do my caller ringtones work then not work on my droid
