Vibrate! Don't just go silent!!!
This is a discussion on Vibrate! Don't just go silent!!! within the Droid X Help forums, part of the Droid X Discussion category; Is there any way, without using a 3rd party app, to change the "Silent Mode" action on the lock screen to go from completely shutting ...
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 39
Thread: Vibrate! Don't just go silent!!!
    Points: 23,189, Level: 93
    Level completed: 84%, Points required for next Level: 161
    250 Experience PointsCreated Album pictures100 Experience PointsThree FriendsTagger Second Class
    hollywood's Avatar
    2093
    Boise, ID
    1,375
    50 times
    Exclamation Vibrate! Don't just go silent!!!
    Is there any way, without using a 3rd party app, to change the "Silent Mode" action on the lock screen to go from completely shutting the phone up, to just putting it on vibrate? Thanks a bunch!
    The Droid was BORN great
    "Be not afraid of greatness. Some are born great, some achieve greatness, and some have greatness thrust upon them..." -William Shakespeare
    Points: 70,935, Level: 100
    Overall activity: 30.1%
    20,493
    876 times
    Quote Originally Posted by hollywood View Post
    Your side volume keys should do this unless you have them "locked" by another app.
    Guidelines of Conduct for DroidXForums.com
    hollywood's Avatar
    2093
    Boise, ID
    1,375
    50 times
    I want it to where I can just turn the screen on, slide my finger from right to left, and it go to vibrate... I don't want to have to unlock the phone, and then press the volume keys just to get it to that point, and then unlock it, and press them again to turn the sound back on... Right now, I am using Silent Mode Jammer... But that's just another process and another icon that I don't want... It would be nice to have the feature of choosing how it puts it into silent mode, rather than just turning off the sound and vibration all together...
    20,493
    876 times
    Your side volume keys should work if your phone is locked. You will have to turn the screen on but then you can adjust the volume without unlocking the screen. However, you cannot have the volume keys locked by another app (mine is locked by EA but I did test it before posting).
    hollywood's Avatar
    2093
    Boise, ID
    1,375
    50 times
    It's not working... I can adjust it as soon as I unlock the phone. You know how most phones have it to where you hold a button down for a few seconds, it will put it on vibrate or silent, whichever you choose? I am wondering if there is a way to change it to where the default for "Sound Off" is to put it on vibrate mode instead of silent mode without the aid of an app...
    hollywood's Avatar
    2093
    Boise, ID
    1,375
    50 times
    Install Silent Mode Jammer from the app store. Lock your phone. Then, press the Home button, and slide the Sound On/Off slider to see how it puts it into Vibrate mose instead of Silent Mode. I want to change the default without that app installed...
    EDIT:
    Make sure it's the regular version and not the EX version. EX does not work...
    20,493
    876 times
    You indicate that you presently have your phone locked - however, if you remove the stock lock function it will give you the slider (left to homescreen / right to silent). Outside of that - I think you are looking at a 3rd app.
    I am not sure why it doesn't work tho - I am using Executive Assistant for my lockscreen and it has the option to "lock volume keys" in settings - which I have checked. However, when I unchecked them, I was able to adjust the volume after I turned the screen on but did not have to unlock the phone to do so.
    Points: 4,457, Level: 42
    Level completed: 54%, Points required for next Level: 93
    jtdiddy's Avatar
    475
    So. Cal.
    166
    I use widget locker...allows you to customize your lock screen
    I have a slider that allows me to switch from ringer, vibrate and silent on my lock screen by just sliding my finger
    hollywood's Avatar
    2093
    Boise, ID
    1,375
    50 times
    By default, it must lock them... Maybe the app gives the option to have them locked (default) or unlock (optional)... Idk...
    20,493
    876 times
    Ok Hollywood - I couldn't even get the app to work LOL...I did check out the website but I haven't brushed up lately on my Chinese so that was no help. However, try this...when you turn your screen on, instead of unlocking, press the back button - do you get the slider?
  1. Vibrate
    By Seven71ne in forum Droid X General Discussion
    Last Post: 07-28-2010, 03:56 PM
  2. Change voicemail ringtone to silent
    By Morbi12 in forum Droid X Audio / Video
    Last Post: 07-23-2010, 09:42 PM
  3. Silent Ringer for Ringtone/Notification
    By LexLuthor in forum Droid X Help
    Last Post: 07-23-2010, 03:15 AM
  4. Replies: 6
    Last Post: 07-19-2010, 09:29 PM
  5. Making phone vibrate while in silent mode
    By mp7123 in forum Droid X Help
    Last Post: 07-19-2010, 09:20 PM
att fusion vibrate
droid x doesn't vibrate
droid x vibration doesn't work
fusion wont vibrate
how to get at&t fusion to vibrate
how to put droid x on silent
how to put the droid x on vibrate
how to turn droid x on vibrate
how to turn vibrate on droid x
vibrate doesn't work on droid x
