Installed Liberty 2.0.1, Titanium Backup restarts Phone
This is a discussion on Installed Liberty 2.0.1, Titanium Backup restarts Phone within the Droid X Help forums, part of the Droid X Discussion category; Hey guys, kind of mad know because i just installed Liberty 2.0.1 for my DX. All was dandy until I want to restore my apps ...
Results 1 to 10 of 14
Thread: Installed Liberty 2.0.1, Titanium Backup restarts Phone
    Points: 1,654, Level: 23
    Level completed: 54%, Points required for next Level: 46
    Tagger Second Class3 months registered100 Experience Points31 days registered7 days registered
    Austin1227 DX's Avatar
    23767
    95
    Hey guys, kind of mad know because i just installed Liberty 2.0.1 for my DX. All was dandy until I want to restore my apps and Titanium Backup just restarts my phone. Any help?
    Points: 29,560, Level: 99
    Level completed: 74%, Points required for next Level: 440
    MICHO's Avatar
    30057
    behind a dumpster
    4,602
    97 times
    Are u doing a full restore? Apps and app data? If so just do the apps try that or install one app at a time.
    Yesterday is history, tomorrow is a mystery, and today is a gift; that's why they call it the present. -Eleanor Roosevelt
    Points: 4,487, Level: 42
    Level completed: 69%, Points required for next Level: 63
    Overall activity: 1.2%
    rudyy's Avatar
    30693
    california
    738
    11 times
    I just reinstalled some apps and widgets using tb on 2.0.1; no problems.
    running gingerbread 602 SBF
    23767
    95
    I shows alot of apps have a dash through them, some i am able to restore though, making me mad...
    Points: 51,541, Level: 100
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    You can't restore system apps, only user apps. Ensure you're just restoring market apps only.
    Points: 9,019, Level: 63
    Level completed: 90%, Points required for next Level: 31
    Overall activity: 2.5%
    firefighterguy's Avatar
    8489
    Colorado
    1,559
    46 times
    I am having the exact same issue. I also tried just the apps. Same result. Tried redownloading off the market. Same result. Tried reistalling from market and retore just the data. Same result. Tried restoring to a stock deodexed backup. Then updated the appsin the market. Same result. Tried restoring stock backup and letting the updates go through again. Same result. Tried my other favorite ROM (R2RemixBeta1). Same result. Tried altering settings both on the pbone and through Titanium. Same result.
    I emailed Joel. He said something about maybe the apps are corrupt. After I told bim all this, he hasn't responded back.
    I also noticed the market was updated to 2.3.6 or something like that. And I tried all of the above again and I had the same result. AGAIN. Did Google do something to lock tbings out or close it up? Are all of these updates for apps for GB FUBAR'ing the rest of us still on Froto waiting for the OTA? I also tried to clear market data and doing the market link doctor. Same result.
    All of this that I have tried was only user apps. More specifically, apps that I have downloaded from the market and backed up.
    I'm starting to get pissed. But as my grandfather used to always say, "It's better to be pissed off than pissed on." Lmao.
    Points: 6,135, Level: 50
    Level completed: 93%, Points required for next Level: 15
    Overall activity: 2.6%
    500 Experience PointsCreated Album pictures250 Experience Points100 Experience Points7 days registered
    eric eakin's Avatar
    3548
    Ca
    1,071
    23 times
    did anyone make a titanium backup in gingerbread prior to these problems?
    Addicted to technology but don't always get it!
    X 2
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Actually its probably the updates for honeycomb causing the issues. So you tried wiping the market data? Settings/apps/manage apps/all/market/force stop/clear data OR you can try uninstalling updates in the market in the same screen as the clear data
    8489
    Colorado
    1,559
    46 times
    Mr. Droid-Xer, sir. I have tried that in settings/Applications/Manage Apps/All Apps/Market/force close and clearing the data. Here's another odd thing. It won't let me uninstall the updates. It is either the whole app or nothing. Lol. And I was a dumbass and changed the number of backups to 1. So now I am FUBAR'ed. Lol. OOOPS!
    (And I noticed I spelled "Froyo" as "Froto." Didn't mean for the Lord of the Rrings reference to slip in there).
    Sent from my DroidX using the Droid X Forum app with help from the little voices in my head
    "King Of The 'Self-Edit'"
    8489
    Colorado
    1,559
    46 times
    Wait. I just reread your post. I have tried that already too - with deleting the updates to the Market. But to no avail.
    Maybe my only other alternative right now is to wait until GB is released...IF it is released. Or break down and flash to GB. I would rather wait until the official release. But I shouldn't hold my breath...
  1. titanium backup
    By giantsfan91 in forum Gingerbread General Discussion
    Last Post: 03-30-2011, 09:41 PM
  2. Replies: 11
    Last Post: 02-13-2011, 06:03 PM
  3. How to use Titanium Backup Pro?
    By jondecker76 in forum Droid X General Discussion
    Last Post: 02-02-2011, 09:20 AM
  4. Phone Restarts With USB Connection
    By jamiecta in forum Droid X Help
    Last Post: 12-28-2010, 04:02 PM
  5. titanium backup
    By dlbrown75 in forum Droid X General Discussion
    Last Post: 11-24-2010, 10:15 PM
liberty titanium
phone restarts after titanium backup
titanium backup liberty
titanium backup rebooting phone
titanium backup reboots
titanium backup restarts
titanium backup restarts phone
titanium backup restarts phone during backup
titanium backup restore reboots
titanium backup system apps liberty
