Can't Boot in recovery, droid x running leaked 2.3 gingerbread
This is a discussion on Can't Boot in recovery, droid x running leaked 2.3 gingerbread within the Droid X Help forums, part of the Droid X Discussion category; Hi, I'm trying to boot into recovery to flash something on my DX. but whenever i bootstrap, then boot into recovery it doesnt work. All ...
Results 1 to 10 of 14
Thread: Can't Boot in recovery, droid x running leaked 2.3 gingerbread
    Andrei3500's Avatar
    23202
    8
    Hi,
    I'm trying to boot into recovery to flash something on my DX. but whenever i bootstrap, then boot into recovery it doesnt work. All i get is the boot logo (red M) then instead of going into recovery all i get is a black screen. You can tell it's still on because you can see the back light.
    Has anyone else encountered this problem with DX gingerbread?
    Thank you!
    Moderator
    Points: 25,450, Level: 96
    Frequent Poster
    mikeinrichmond's Avatar
    9010
    Richmond, Va
    7,668
    392 times
    Quote Originally Posted by Andrei3500 View Post
    Hi,
    Thank you!
    Yes, this is because you are using the original version of Bootstrap in GB, which you need to uncheck the USB debugging in Settings-Applications-Development...That will fix it...
    Lots of good GB info here:
    Gingerbread Leak FAQs
    and make sure you make a backup of stock GB before flashing any other Roms or Themes to it. JIC...
    Andrei3500's Avatar
    23202
    8
    Ahh, many thanks!! I flashed the off screen CRT animation. It's silly, but i love that thing. Your solution worked like a charm. Thanks again!
    Points: 866, Level: 15
    Level completed: 66%, Points required for next Level: 34
    Mrphysics23's Avatar
    32969
    18
    You need d2 bootstrapper
    Points: 38,766, Level: 100
    Overall activity: 64.5%
    1KDS's Avatar
    3981
    6,904
    573 times
    You don't need d2 bootstrap, just follow mikes directions above
    From the X
    Moderator
    Frequent Poster
    9010
    Richmond, Va
    7,668
    392 times
    Welcome..
    (Swypin' GB on the go)
    njdroidx's Avatar
    35600
    Had same issue, unrooted 2.3 GB. Boot into Recovery and search key did not work.
    Hit UP/Down volume at same time and recovery screen comes up. use up/down to choose option. Use on/off button instead of Camera button to select action.
    cleopete likes this.
    Spock's Avatar
    57451
    Did not work for me
    HTC Desire with Gingerbread 2.3. It does not boot in the recovery mode even USB debugging is uncheck :-(
    Points: 6,623, Level: 53
    Level completed: 37%, Points required for next Level: 127
    Overall activity: 5.9%
    casper55117's Avatar
    56375
    Mar 2012
    minnesnowda
    1,008
    12 times
    Quote Originally Posted by Spock View Post
    1 how are you trying to boot in recovery. 2 are you rooted. 3. not to sound like a jerk but this is a forum for the motorola droid x and the droid x2. not many people here will be able to help. but i will try
    Spock's Avatar
    57451
    Hi. Sorry, didn't want to intrude to Motorola. Thought it was a problem of the system. Anyway, I tried as I always did: hold volume down and switch the phone on and yes the phone is rooted. I wanted to restore my nandroid backup, but since I couldn't I did something else and now the phone works. Thanks anyway for your answer.
    Sent from my MZ601 using Tapatalk
  1. AOSP email app on Gingerbread leaked rom??
    By jnasmith in forum Droid X Hacks
    Last Post: 03-28-2011, 01:17 PM
  2. Replies: 8
    Last Post: 01-13-2011, 10:16 PM
  3. Droid X Boot Looping After RSDLite Flash -- No Recovery
    By robbiem in forum Droid X Rescue Squad
    Last Post: 12-27-2010, 03:35 AM
  4. Replies: 6
    Last Post: 12-14-2010, 08:28 PM
  5. Droid X won't boot past M screen or into recovery mode
    By johlste in forum Droid X Rescue Squad
    Last Post: 12-05-2010, 10:05 PM
boot droid x into recovery
boot droid x into recovery gingerbread
boot into recovery droid x gingerbread
droid x boot into recovery
droid x boot into recovery gingerbread
droid x gingerbread boot into recovery
droid x gingerbread recovery
droid x recovery gingerbread
how to boot droid x into recovery
how to boot into recovery droid x gingerbread
