Caps and punctuation when using voice to text.
This is a discussion on Caps and punctuation when using voice to text. within the Droid X Help forums, part of the Droid X Discussion category; Is there a way to use caps and punctuation when using the built-in voice to text function? I'm primarily interested in this function as it ...
Results 1 to 10 of 17
Thread: Caps and punctuation when using voice to text.
    set theorist's Avatar
    3710
    Westchester County, New York
    22
    Is there a way to use caps and punctuation when using the built-in voice to text function? I'm primarily interested in this function as it pertains to dictating an e-mail.
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    When dictating meassage, speak your punctuation as well...example - hi comma how are you question mark I hope good. It will add the punctuation & capitalize next word.
    Sent from my DROIDX
    Points: 2,109, Level: 27
    Level completed: 73%, Points required for next Level: 41
    500 Experience Points250 Experience PointsThree Friends100 Experience Points7 days registered
    bozidar0's Avatar
    1510
    USA
    248
    7 times
    Wow, I never would have realized that! I still need to train my X to my voice. but it does a good job for not being trained.
    -Bozidar0, PHP Programmer
    Rooted, (FlyX, Black Glass), Droid X 2.2
    3710
    22
    WOW!!! Voice training? Please, tell me how. I'm real interested in improving my recognition accuracy.
    Points: 2,023, Level: 27
    Level completed: 16%, Points required for next Level: 127
    pastrygirl's Avatar
    874
    95
    13 times
    I just read about it in another thread. Pull up the voice command menu, then press the menu button and go to Settings. The adaptation option is there. I just did it and am hoping it makes a big difference!
    Tagger Second Class500 Experience Points250 Experience Points100 Experience Points7 days registered
    baniels's Avatar
    30
    52556
    369
    26 times
    Something tells me the training isn't going to effect the accuracy of the dictation when using the voice-to-text found when using the microphone icon within the keyboard. I am thinking that Motorola's voice commands is different than google's text-to-speech used natively in all 2.1+ Android systems.
    You will notice that if you try to use the microphone option within the keyboard if your phone doesn't have an active data connection, it won't even let you speak. It will say there is a connection problem. It sends the audio to the cloud for voice-to-text.
    Quote Originally Posted by pastrygirl View Post
    Points: 1,152, Level: 18
    barryvabeach's Avatar
    1396
    10
    Baniels, I agree. In fact I have tried to find another speech recognition software because I get the error message that it can't connect to server ( after you wait for a while for it to do the conversion) fairly often. Dragon is available for BB, but it doesn't seem like it is available for Droid.
    X Lurker druit's Avatar
    3776
    Virginia
    11
    If you go into voice command , then setting , then audio adaptation it will work much better. I have an accent ( French ) and it works for me very well, I do not type text message any more , just use voice call and perfect even with the French accent and trust me I do have an accent
    Points: 4,469, Level: 42
    Level completed: 60%, Points required for next Level: 81
    BOWIE's Avatar
    1078
    Scottsdale, AZ
    603
    39 times
    Wow exclamation point I didn apostrophe t know that it had those features period Other than crashing comma the voice program has been working very well for me period
    pastrygirl's Avatar
    874
    95
    13 times
    Well, I went through adaptation and now it works MUCH worse for me. Is there a way to undo it?
  1. DROID X - Voice Command, Voice Search
    Last Post: 02-11-2011, 12:53 AM
  2. Voice-to-text working sporadically
    By drummer in forum Droid X Help
    Last Post: 08-03-2010, 09:19 PM
  3. Voice command - can't get it to text
    By DX77 in forum Droid X Help
    Last Post: 07-22-2010, 02:49 AM
  4. Cancelling Text Plan Because of how Aesome Google Voice SMS Works
    By floydiannyc in forum Droid X General Discussion
    Last Post: 07-21-2010, 07:09 PM
  5. DROID X - Text Entry, Swype, Speech to Text
    Last Post: 07-15-2010, 01:36 AM
Google voice punctuation
android speech to text punctuation
android voice to text punctuation
capitalize words using google voice
how do get punctuation on samsung 5 using google voice
how do you put in punctuation when using a talk to text program?
how to add punctuation in voice to text
how to put a space in voice texting
put punctuation in speech to text
voice text punctuation
