How to turn your android phone into a fully automated super phone
This is a discussion on How to turn your android phone into a fully automated super phone within the Droid X Help forums, part of the Droid X Discussion category; I would love for someone to do that.i downloaded but have no clue how to work it! Sent from my DROIDX using Tapatalk...
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 22
Like Tree8Likes
Thread: How to turn your android phone into a fully automated super phone
    Points: 5,026, Level: 45
    Level completed: 38%, Points required for next Level: 124
    Overall activity: 2.2%
    redwinger2001's Avatar
    734
    North Carolina
    380
    8 times
    250 Experience Points31 days registered7 days registered100 Experience Points
    brian.lucas's Avatar
    468
    Bellevue, NE
    37
    Well after damn near an hour downloading this tiny file... my droid won't install it... says "There is a problem parsing the package"
    EDIT: Well now I feel stupid. Saw a download link labled "fast download" on the site. Used it and it finished in less than a second and this file installed just fine. Will be playing for a while
    UPDATE: Set up my first simple action. 50m (meter not mile) radius around my house -> enable WiFi. Went for a walk around the block. It turned off when I got to the corner and turned back on when I got back! Positive so far!
    V/R
    Brian Lucas
    Points: 70,911, Level: 100
    Overall activity: 29.7%
    20,492
    876 times
    Quote Originally Posted by redwinger2001 View Post
    Has anyone tried this out? Seems pretty cool but I wanted to get others opinion before making an impulse buy. I think I'm going app crazy!!
    Lifehacker, tips and downloads for getting things done
    There was a thread on this earlier today as well...
    Store using the tasker app?
    Guidelines of Conduct for DroidXForums.com
    734
    North Carolina
    380
    8 times
    I'm feeling pretty stupid. I don't have a clue how to even start using this app. Went to the dev website and it seems very complicated but then again.....i'm techno challenged. Hope to post something wonderful and fun soon.
    Points: 2,557, Level: 30
    Level completed: 72%, Points required for next Level: 43
    3 months registered31 days registered250 Experience Points7 days registered100 Experience Points
    nojogray's Avatar
    3383
    Annapolis, Md
    67
    I usually won't pay for an app but I absolutely love this one. It is kind of like Locale but much more versatile (and a little cheaper). It has a learning curve but if you take the time to figure it out, your life will be so much easier. Similar to that site's example, my phone is set up to turn on GPS and bluetooth and max ringer volume when ever I put it in the car dock and return the settings when I pull it out. Huge time saver.
    734
    North Carolina
    380
    8 times
    I'm at the wiki site now trying to figure out a few simple things. Can't wait to play with this. Love your car dock setup.
  8. #17
    X Pursuant Achievements:
    Jaxidian's Avatar
    47
    Indianapolis
    694
    48 times
    I'm definitely giving this app a shot. Thanks for the heads up on this!
  9. #18
    468
    Bellevue, NE
    37
    hopefully I'll have some time to play with this tomorrow and get some good profiles set up. Will let you all know how it goes! Night!
    V/R
    Brian Lucas
  10. #19
    250 Experience Points31 days registered100 Experience Points7 days registered
    pauliewalnutted's Avatar
    1285
    29
    Yes its quite complicated and overwhelming at first, but after an hour or two playing with it and reading the article from lifehacker, i've got the hang of it. It is a greaaat app
  11. #20
    Jaxidian's Avatar
    47
    Indianapolis
    694
    48 times
    I spent about 20 minutes and had the following setup:
    Home Profile (wifi and some other stuff turned on)
    Work Profile (wifi, bluetooth, and some other stuff turned on)
    Docked (wifi off, bluetooth on, bright screen except at night, and some other stuff)
    Screen on (turn GPS on)
    Screen off (turn GPS off)
    I've noticed that my Work/Home profiles (based on GPS location) don't always trigger properly even though I see the GPS icon up in my notification bar. However, if I fire up GMaps and hit My Location, that tends to kick it in the butt to get working. Kinda strange there...
  1. Replies: 7
    Last Post: 07-30-2010, 10:35 AM
  2. Phone contacts don't show up in the phone
    By bobgoodfellow in forum Droid X Help
    Last Post: 07-28-2010, 03:33 PM
  3. Super K.O Boxing 2
    By phimuskapsi in forum Droid X Games
    Last Post: 07-23-2010, 08:56 PM
  4. Love my phone!!!!!
    By X-tac23 in forum Droid X General Discussion
    Last Post: 07-19-2010, 07:13 PM
  5. What was your last phone?
    By Jaxidian in forum New Member Introductions & Site Assistance
    Last Post: 07-10-2010, 03:15 PM
how to supe up an android phone
how to turn ur droid into a super phone
how to turn your android phone into a fully-automated superphone
how to turn your droid x into a iphone
how-to-turn-your-android-phone-into-a-fully automated-superphone
make my android into a superphone
turn my i phone into a droid x
turn your android into a super phone
turn your android phone into a superphone
turn your phone into a pager
