Im BEGGING for HELP please HELP!
This is a discussion on Im BEGGING for HELP please HELP! within the Droid X Help forums, part of the Droid X Discussion category; Ok so I dont know what I did, now when ever I turn on my phone it says Clockworkmod Recovery.. It has green writing.. I ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Im BEGGING for HELP please HELP!
    Points: 1,112, Level: 18
    Tagger First Class250 Experience Points7 days registered100 Experience PointsTagger Second Class
    AndroidGuyIsMe's Avatar
    31222
    87
    Ok so I dont know what I did, now when ever I turn on my phone it says Clockworkmod Recovery.. It has green writing.. I WANT IT OFF! Please guys help me.. What should I do? Should I go to verizon? Please help
    Points: 4,820, Level: 44
    Level completed: 35%, Points required for next Level: 130
    Carpetman's Avatar
    2459
    371
    Quote Originally Posted by AndroidGuyIsMe View Post
    Use the volume button to scroll to reboot and then press camera button. Should reboot and be good to go.
    Points: 3,746, Level: 38
    Level completed: 64%, Points required for next Level: 54
    xrazedx's Avatar
    15299
    875
    24 times
    Have you pressed the camera button while "reboot system now" was highlighted?
    Edit: Got ninja'd.
    Relentless
    Rooted Droid X
    Overclocked at 1.35 GHz
    A man should look for what is, and not for what he thinks should be.
    -Albert Einstein
    For anyone interested in undervolting, read Undervolting Guide.
    Points: 6,119, Level: 50
    Level completed: 85%, Points required for next Level: 31
    Overall activity: 2.7%
    fc127's Avatar
    27223
    Cortland, NY
    1,173
    36 times
    And you should definitely NOT take it to Verizon...
    Root .602 & .605 info here.
    Need to SBF? Try this.
    Points: 17,755, Level: 84
    Level completed: 81%, Points required for next Level: 95
    Overall activity: 21.2%
    maybish's Avatar
    20852
    new jersey
    5,704
    251 times
    When youre in your phone go into the droid x bootstrap app. Hit bootstrap recovery. After success hit ok. Then back out. I also like to go into settings apps manage then find the bootstrap app and force close it. Now try a reboot. Hope this helps!
    *~~*Mays Droid X*~~*
    Points: 12,048, Level: 71
    Level completed: 99%, Points required for next Level: 2
    Overall activity: 10.9%
    cynkrzy's Avatar
    23242
    San Luis Obispo
    1,142
    85 times
    If you're running the Liberty ROM there is an option in the Settings/Liberty menu that allows you to always boot into Clockwork Recovery. If this is set anytime you boot the phone it will boot into Clockwork. This is a rather nice safety feature when you're experimenting with ROM settings, and nothing to be "worried" about. Whatever you do, do not take it to a Verizon store, cuz if they know anything at all, they'll know the phone has boot "rooted"
    P.S. - If you are running Liberty and that option is selected just press to un-select it.
    Experience is a Cruel Instructor. First you take the test, then you learn the lesson!
    31222
    87
    Wait should I reinstall the bootstrap thing and then do recovery.. I just want it to be gone so when I turn on my phone I dont have to go to the green words screen and do reboot and stuff
    31222
    87
    Ok right now it says ClockworkMod Recovery v2.5.0.6, I know how to get into my phone normally and it works fine, I just want to get rid of having to click on reboot system now. I just want my phone to turn on normally... Any ideas?
    31222
    87
    This is the message I get when I click Bootstrap Recovery... Error running exec()Command: [su, -c . /data/data/com.koushikdutta.droidxbootstrap/files/surunner.sh]
    Moderator
    Points: 25,450, Level: 96
    Frequent Poster
    mikeinrichmond's Avatar
    9010
    Richmond, Va
    7,668
    392 times
    Please clarify, do you want to get rid of Bootstrap completely, or just not boot into the green clockwork recovery each time the phone reboots?
    If the latter, did you try May's suggestion of hitting just Reboot Recovery then backing out and rebooting?
    If you want to remove it completely, here are the instructions:
    [HOW TO] Install and Remove Bootstrap Recovery
atrix 2 bootstrap error running exec
atrix 2 bootstrap remove
bootstrap recovery error
clockworkmod recovery v2.5.0.6
clockworkmod recovery v2.5.0.6 droid x how to get phone to turn back on
droid please say a command
force droid x into clockworkmod
get rid of say a command on droid razr
get rid of the please say a command on droid razr
how to get rid of bootstrap recovery using root explorer
how to get rid of please say a command droid
how to get rid of please say a command on droid
how to get rid of the please say a command on a droid x
root droid x bootstrap recovery error
want to unroot droid x and get phone back to normal
