Im BEGGING for HELP please HELP!
This is a discussion on Im BEGGING for HELP please HELP! within the Droid X Help forums, part of the Droid X Discussion category; Did you attempt to un-install Bootstrap Recovery ? - Even if you un-install the app, it doesn't remove ClockworkMod from the phone. There are specific ...
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Im BEGGING for HELP please HELP!
  1. #21
    Points: 12,048, Level: 71
    Level completed: 99%, Points required for next Level: 2
    Overall activity: 10.9%
    cynkrzy's Avatar
    23242
    San Luis Obispo
    1,142
    85 times
    Did you attempt to un-install Bootstrap Recovery ? - Even if you un-install the app, it doesn't remove ClockworkMod from the phone. There are specific instructions for removing Bootstrap/Clockwork mod in one of the earlier replies. To do that you'll need to buy an application called RootExplorer from the market. It's a few bucks but it's the only way short of an SBF to remove ClockworkMod from the phone.
    The error your getting is from a script file that Bootstrap recovery installs.
    Experience is a Cruel Instructor. First you take the test, then you learn the lesson!
  3. #22
    Points: 1,112, Level: 18
    Tagger First Class250 Experience Points7 days registered100 Experience PointsTagger Second Class
    AndroidGuyIsMe's Avatar
    31222
    87
    Quote Originally Posted by joshw0000 View Post
    After the phone has successfully booted, open droid x bootstrap, click "bootstrap recovery", click ok on the pop-up box, now click "reboot recovery". It will boot you to the screen you're trying to get rid of but just trust me and do it. Now click thr camera button and the phone will reboot normally. Your phone SHOULD reboot normally from now on.
    I could tell you the technical reason why this works for most people but I'm sure you don't care. Let me know if it works for you!
    I did what you said and it still boots the same
  4. #23
    31222
    87
    Quote Originally Posted by cynkrzy View Post
    I installed RootExplorer now how do I get rid of clockworkmod
  5. #24
    Points: 38,766, Level: 100
    Overall activity: 64.5%
    1KDS's Avatar
    3981
    6,904
    573 times
    Quote Originally Posted by Droid-Xer View Post
    How to remove Droid X Bootstrap through ROOT EXPLORER
    Uninstall bootstrap app first
    1. Click mount r/w
    2. DELETE
    a) system/bin/hijack
    b) system/bin/logwrapper
    3. RENAME
    a) system/bin/logwrapper.bin
    4. TO
    5char
  6. #25
    31222
    87
    Ok I did all that and IT WORKSSS!! Now can I just un-root and not have to deal with this crapola?
  7. #26
    Moderator
    Points: 25,450, Level: 96
    Frequent Poster
    mikeinrichmond's Avatar
    9010
    Richmond, Va
    7,668
    392 times
    You don't need to unroot. If you do, you won't be able to use any apps that need root access if you have any...
  8. #27
    31222
    87
    Quote Originally Posted by mikeinrichmond View Post
    Yeah, i dont think im ever rooting or messing with my phone again, im not too great when it comes to thinks likes this
  9. #28
    Points: 5,073, Level: 45
    Level completed: 62%, Points required for next Level: 77
    lynneddington's Avatar
    12076
    mid tennessee
    997
    30 times
    Sounds like you just need to sbf. Then you are back to out of the box
    {ROOTED/ 591 apex 2.0beta watermarked//OC'ed 1200@66vsel, now the wifes} Tbolt, rooted rommed kernaled, oc'ed 1.4-1.92
  10. #29
    Advocate X
    Points: 24,548, Level: 95
    Overall activity: 31.6%
    WugFresh's Avatar
    19823
    Earth
    5,135
    455 times
    If you rooted with z4, there is an unroot option. Honestlly though.. if you install bootstrapper again I have a feeling it would just work how its supposed to. Just so you know, bootstrapper will always boot into recovery if the battery fully dies or you remove the battery and put it back in, other than that it should boot up normally. I usually install rom manager and use it to flash clockwork mod.. I think that might also fix your bootup problem.. its not advised to actually use ROM manager but using it just to do that once should be a fix. Good luck to you.
    I suggest reading a bit so you are, more familiar and comfortable with the benefits of root, if you want to go that route. If not, there's no harm in just running stock.. alot of people do. Here's some info;
    Why Root?
    How to Optimize Battery Life & Speed
    {{ WugFresh }}
    Other helpful resources:
atrix 2 bootstrap error running exec
atrix 2 bootstrap remove
bootstrap recovery error
clockworkmod recovery v2.5.0.6
clockworkmod recovery v2.5.0.6 droid x how to get phone to turn back on
droid please say a command
force droid x into clockworkmod
get rid of say a command on droid razr
get rid of the please say a command on droid razr
how to get rid of bootstrap recovery using root explorer
how to get rid of please say a command droid
how to get rid of please say a command on droid
how to get rid of the please say a command on a droid x
root droid x bootstrap recovery error
want to unroot droid x and get phone back to normal
