droid x to metro pcs help :(
This is a discussion on droid x to metro pcs help :( within the Droid X Help forums, part of the Droid X Discussion category; Hi, I rooted and installed a ROM (apex 1.4) onto my droid X, then added my ESN into metro, confirmed it, got my phone number, ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: droid x to metro pcs help :(
    sparky100's Avatar
    31171
    15
    Hi, I rooted and installed a ROM (apex 1.4) onto my droid X, then added my ESN into metro, confirmed it, got my phone number, loaded the PRL, (basically followed the guide here: Say buh-bye to VZW: Flashing your Droid X to Cricket or MetroPCS)
    however, after doing all of that instead of the MMS settings, I do not get metropcs when i dial *611. I get a error saying ranger wireless doesnt support it or something. When I dial *228, I get verizon trying to activate it.
    My texting works fine, however, but I really want my voice calling to work...any ideas? =\\
    Moderator
    Points: 25,450, Level: 96
    mikeinrichmond's Avatar
    9010
    Richmond, Va
    7,750
    421 times
    I do not believe you can flash a custom Rom and get this to work. The custom Rom is written with Verizon's radios as part of the build. Go back to stock settings and try again...
    Droid X Forums Guidelines of Conduct
    sparky100's Avatar
    31171
    15
    where can I find a stock rom that will work for me?
    Moderator
    9010
    Richmond, Va
    7,750
    421 times
    What Android version are you on? (Settings-About phone)
    Is the media playing fine in Apex?
    If you are on Android version 2.2.1 and the media files in Apex are playing well, then you should be able to use the maderstcok.zip file from clockwork (flash it like you did Apex) to get back to unrooted stock form. Then re-root, and try Metro again.. Here's the thread:
    maderstcok - OTA 2.3.340 update.zip
    sparky100's Avatar
    31171
    15
    I'm running 2.2.1 and media works, yeah?
    Alright i'll unroot + stock with that file and see what happens. Thanks!
    Moderator
    9010
    Richmond, Va
    7,750
    421 times
    Quote Originally Posted by sparky100 View Post
    No you don't unroot, after you use it and reboot you will be unrooted. Then re-root...
    sparky100's Avatar
    31171
    15
    That's what I meant haha sorry. That link you gave me will unroot it. Thanks. I'll let you know if it worked or not in a few. =\
    sparky100's Avatar
    31171
    15
    the maderstcok.zip did not completely wipe my phone to stock? I still have the apex boot loader image, and my apex background, apps, etc.
    I installed the .zip file from the bootloader, did i do something wrong?
    EDIT: My fault. I forgot to do a factory reset. So I just did that now.
    Moderator
    9010
    Richmond, Va
    7,750
    421 times
    Yes, after the reset, you'll be stock, but still have Bootstrap installed. Once you re-root, you'll be able to use it again if needed...
    sparky100's Avatar
    31171
    15
    going back to stock did not fix it. =\ i still get the "could not complete call" when doing *611, instead of getting metropcs customer service...
  1. Windows Phone Metro UI app for Android
    By pimpannara in forum Droid X Apps
    Last Post: 12-11-2010, 10:46 AM
  2. metro pcs flash
    By nps1221 in forum Droid X Help
    Last Post: 12-06-2010, 10:42 AM
  3. Droid X on Metro PCS upgrading to FROYO
    By New-b_Droid_Usr in forum Droid X Help
    Last Post: 11-19-2010, 01:57 PM
  4. Good Verizon Store in DC Metro Area?
    By Charlie97L in forum Droid X General Discussion
    Last Post: 11-04-2010, 09:50 AM
DROID X METROPCS ROM
activate droid x metro pcs
activating rooted razr to metropcs
droid x evdo prl
droid x metro pcs rom
flash droid x to metro pcs
how to add droid x esn to metro pcs
how to root droid x to metro pcs
jailbreak droid x to metro pcs
metropcs prl droid x
