What prl did you use?
What did you use for the MIN? I believe you actually need to get this from cricket over the phone.
This is a discussion on droid x to metro pcs help :( within the Droid X Help forums, part of the Droid X Discussion category; What prl did you use? What did you use for the MIN? I believe you actually need to get this from cricket over the phone....
I called MetroPCS and am using the MIN they provided me. I put in a couple dummy MIN's, including just my phone #, to see if that would change anything, and it disabled my texting, so i know the MIN is good.
The PRL I am using is the "latest EVDO prl" stickied on howardforums.
anyone have any ideas?! =( i'd rather not be stuck with a phone that can't make calls...
Go into the ##program menu, then test mode, then user activation. Make sure the cdma system id matches the one they gave you. It should be one to five digits I believe.
Might be some good info here as well.
http://www.mobile-files.us/forum.php
And here's a thread where someone had the same problem.
http://pdaphonehome.com/forums/kyoce...-home-sid.html
Try dialing *22804.
Here's the Cricket system id numbers if you need them.
06441 Tulsa, OK
06439 Tucson, AZ
06425 Spokane, WA
06415 Santa Fe, NM
06371 Modesto, CA
06365 Merced, CA
06323 Hot Springs, AR
06249 Albuquerque, NM
06160 Utica-Rome, NY
06005 Rochester, NY
05945 Pittsburgh, PA
05914 Omaha, NE
05756 Lincoln, NE
05618 Hickory-Lenoir-Morganton, NC
05586 Greensboro--Winston-Salem--High Point, NC
05582 Greeley, CO
05540 Fort Collins-Loveland, CO
05508 Evansville, IN
05458 Denver, CO
05450 Dayton-Springfield, OH
05386 Charlotte-Gastonia, NC
05361 Buffalo-Niagara Falls, NY
05173 Wichita, KS
05145 Fresno, CA / Merced, CA / Modesto, CA / Visalia-Porterville-Hanford, CA
05111 Temple-Killeen, TX
05105 Syracuse, NY
05033 San Antonio, TX
05027 Salt Lake City-Ogden, UT
05019 Salem-Albany-Corvallis, OR
04973 Reno, NV
04961 Pueblo, CO
04959 Provo-Orem, UT
04945 Portland, OR
04925 Pine Bluff, AR
04923 Phoenix, AZ
04857 Nashville, TN
04849 Muskegon, MI
04809 Memphis, TN
04771 Macon-Warner Robins, GA
04755 Louisville, KY
04743 Little Rock, AR
04733 Lexington, KY
04729 San Diego, CA
04717 Las Cruces, NM
04712 Lansing, MI
04693 Knoxville, TN
04681 Kansas City, MO
04667 Jonesboro-Paragould, AR
04621 Houston, TX
04567 Grand Rapids, MI
04543 Fresno, CA 04535 Fort Smith, AR
04509 Fayetteville-Springdale-Rogers, AR
04485 El Paso, TX
04413 Columbus, GA
04407 Colorado Springs, CO
04395 Clarksville, TN-Hopkinsville, KY
04391 Cincinnati, OH
04381 Chattanooga, TN
04343 Bryan-College Station, TX
04325 Boise-Nampa, ID
04279 Austin, TX
What city/region you in sparky?
snow -- Thanks a million for the effort into helping me fix this problem!!
i'm near lancaster, PA, and manually set my cdma system id to 96 -- harrisburg, pa. it was what i used before with pageplus and worked fine. is that what is causing me issues?
i'll try changing the sid to one of the ones you suggested and see if that helps. ill look at the thread posts you linked also.
let you know how it goes. thanks!
edit: dialing *22804 brings up the verizon activation. the forum you gave me was for someone with cricket, instead of metropcs. I'll change my SID real quick and see if that helps.
edit 2: in test mode, my system ID and network ID are both 8. is that a problem? my SID and NID are supposed to be 96 / 65535. but Idk if in my test mode those are the same things.
You definitely need a five digit sid. I'll find the one for your area. Also, link me to the prl you installed?
