How do I find text messages that have been sent?
This is a discussion on How do I find text messages that have been sent? within the Droid X Help forums, part of the Droid X Discussion category; This may be a dumb and easy question, but I guess I am just used to my old cell phone. On my old phone, for ...
Thread: How do I find text messages that have been sent?
    This may be a dumb and easy question, but I guess I am just used to my old cell phone. On my old phone, for my text messaging, they had "messages" and you had your choice to select "inbox", "sent", "drafts", etc.. I don't see that on this new droid x. Everytime I go to text messages, it only shows my last text, leaving me unable to see a text that I sent hours prior. Is there an app or something that I should know about.
    karmajay's Avatar
    237
    USF, FL
    138
    If u choose the person or text you will se a history of all the texts you have sent back and fourth
    Good question
    Hi, not a dumb question at all. I saw the answer but do not understand it. Can you explain? I would like to know the answer. Thanks in advance. my email is patenlaw@aol.com.
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    If you open your stock text messaging app or whichever app you are using for text messaging, you will see your history sorted by contacts - all messages (sent and received) are logged under the contact - there are not separate boxes for them. Just tap on the contact and you will view a threaded history of the texts...
    Points: 2,144, Level: 27
    Level completed: 96%, Points required for next Level: 6
    Jamr's Avatar
    9957
    24
    The way to see texts sent is to look at the person you sent the particular text to.
    After opening " Text Messaging" click on any person in the list. you will then see text bubbles showing the conversation between you and that person. The Grey are your outgoing texts and the beige are the incoming or texts sent from that persons phone number.
    I do not know of a way to see just all outgoing texts.
    Hope this helps.
  1. Replies: 23
    Last Post: 09-28-2013, 08:33 AM
  2. Transfer Text Messages
    By biglu in forum Droid X Help
    Last Post: 09-29-2011, 10:38 PM
  3. Text Messages Take Forever to Load
    By thecta in forum Droid X Help
    Last Post: 07-25-2010, 05:22 PM
  4. cancel text messages with Handcent
    By Jimk in forum Droid X Apps
    Last Post: 07-24-2010, 08:49 PM
  5. Can't retrieve text messages
    By teach17603 in forum Droid X Help
    Last Post: 07-19-2010, 08:58 PM
how to check sent messages on android
how to check text messages on android
how to find old text messages on android
how to find sent text messages on android
how to find sent text messages on droid
how to see sent messages on android
how to see sent text messages on android
how to view sent messages on android
view sent text messages
view sent text messages on android
