does Vibration affect the battery?
This is a discussion on does Vibration affect the battery? within the Droid X Help forums, part of the Droid X Discussion category; OK, I'm rollin Liberty 1.5 and am using the Gingerbread Keyboard. In settings, I have it set to "Vibrate on Keypress". With the small keys ...
Thread: does Vibration affect the battery?
    Points: 2,426, Level: 29
    Level completed: 84%, Points required for next Level: 24
    TeeX's Avatar
    19502
    191
    With the small keys it lets me feel where the key buttons are easier, and let's me have fewer typo's.
    BUT...
    Does having the vibration on affect my battery life? If so, how much of a difference does it actually make if I turn the keyboard vibration off?
    Points: 9,907, Level: 66
    ToeJamm57's Avatar
    6466
    Michigan
    2,463
    64 times
    I will affect battery. How much would depend on use. If you are a high volume text user it will certainly add to your battery drain.
    Points: 3,019, Level: 33
    Level completed: 80%, Points required for next Level: 31
    Cananot's Avatar
    28762
    Richmond,Virginia
    149
    I use to use that keyboard cause I txt all day and I mean all day ,6:30 I started txting by 10am I was at 70% at noon was at 40% had to charge it at 2 cause it was almost dead I like that feature but the X batterys suck now If you get that big huge extra battery for it then you have no problems whats so ever but its big and its an after market battery but its like 2 batterys in one.
    DROID X ROOTED AND RUNNING LIBERTY 2.0.1 ROM
    Conquerors never, never conquer a nation to bring freedom. They brought control.
  1. Incoming text vibration
    By carolnim in forum Droid X Help
    Last Post: 12-15-2010, 06:24 AM
  2. Vibration
    By gravybird in forum Droid X General Discussion
    Last Post: 11-11-2010, 09:48 AM
  3. Can a magnet affect the DX?
    By ajr1992 in forum Droid X Help
    Last Post: 10-11-2010, 08:00 AM
  4. Does overcharging the phone and keeping the screen on negatively affect it?
    By TheBoyPat in forum Droid X General Discussion
    Last Post: 09-19-2010, 11:45 AM
  5. Does the capacity of the SD card affect the speed of the processing?
    By boblinfoto in forum Droid X General Discussion
    Last Post: 08-23-2010, 09:20 PM
does vibrate drain battery
does vibrate drain your battery
does vibrate kill battery
does vibrate kill your battery
does vibrate use more battery
does vibration affect battery
does vibration consume battery
does vibration waste battery
vibrate kills phone battery
vibration effect on battery
