Text msgs won't go through to certain people...please help!
This is a discussion on Text msgs won't go through to certain people...please help! within the Droid X Help forums, part of the Droid X Discussion category; So with a small percentage of my contacts, text messages won't go through. I've spent hours poring over threads and searching to no avail. I ...
Results 1 to 2 of 2
Thread: Text msgs won't go through to certain people...please help!
    Tagger Second Class
    lylefk's Avatar
    3512
    So with a small percentage of my contacts, text messages won't go through. I've spent hours poring over threads and searching to no avail. I tried removing all dashes and + from the contact with no luck. I even went into my contacts from my pc through gmail to remove dashes when the phone wouldn't...no luck.
    Here is the weird thing. The first time it did this, I tried manually entering the phone # in the 'to' field and that contact has worked normally since then. I just tried this again and it didn't work. Well, 4 texts went through and then it stopped working.
    It is not carrier specific. They are all saved under 'gmail contacts'. I can't seem to find a pattern.
    Please, any help or suggestions are appreciated. I'm frustrated!
    xKnightMare's Avatar
    1935
    13
    I had the same problem with those dashes. I edited my contacts in Microsoft Outlook without the dashes, You can google how to remove the country code from contacts, then delete your google contacts, and then upload the Outlook contacts to Google and it should sync to your phone with no problems.
    For some reason when I tried to just delete the dashes just in google, it still would put the dashes back.
  1. Can people hack or see your info?
    By droidxer in forum Droid X General Discussion
    Last Post: 07-23-2010, 06:04 PM
  2. This May Help People That Are Having Trouble Rooting
    By Domino in forum Droid X Hacks
    Last Post: 07-22-2010, 04:28 PM
  3. What's up good people?
    By kegstand in forum New Member Introductions & Site Assistance
    Last Post: 07-15-2010, 02:34 PM
  4. Replies: 91
    Last Post: 07-15-2010, 12:03 PM
  5. DROID X - Text Entry, Swype, Speech to Text
    Last Post: 07-15-2010, 12:36 AM
text won't go through
why do some of my texts not go through
why my text won't go through
why my texts wont go through
why text messages won't go through
why won't my text go through
why won't my texts go through
why wont a text go through
why wont my text go through
why wont my text messages go through
