Droid X wont go past "touch the android to begin" screen after factory reset :(
This is a discussion on Droid X wont go past "touch the android to begin" screen after factory reset :( within the Droid X Help forums, part of the Droid X Discussion category; I recently rooted my Droid X and my friend was messing with it and did a factory reset, and now it wont let me go ...
Thread: Droid X wont go past "touch the android to begin" screen after factory reset :(
    Points: 647, Level: 12
    Level completed: 94%, Points required for next Level: 3
    jaimitoboy's Avatar
    31161
    Unhappy Droid X wont go past "touch the android to begin" screen after factory reset :(
    I recently rooted my Droid X and my friend was messing with it and did a factory reset, and now it wont let me go past the "touch the android to begin" screen. I can click it, it even highlights the android when i click it but it wont do anything. Im not sure if the rooting has anything to do with it, but if anyone can help me out id appreciate it plz
    Points: 1,555, Level: 22
    dirtyfingers's Avatar
    26573
    Wisconsin
    125
    Maybe try to reboot the phone and see if that will let you past it, also don't let your friend play with your phone anymore EVER!
    Liberty 1.5, WatermarkD Theme, Black Market, OC'd 1.2 GHz
    Points: 10,712, Level: 68
    Level completed: 66%, Points required for next Level: 138
    Dustin0308's Avatar
    24203
    1,490
    37 times
    from the top left of the screen, touch the upper left corner, then upper right, then lower right, then lower left. this will bypass that setup screen for ya. did you make a stock backup with bootstrapper after root?
    LiBeRtY ONEPOINTFIVE
    Moderator
    Points: 25,450, Level: 96
    Frequent Poster
    mikeinrichmond's Avatar
    9010
    Richmond, Va
    7,668
    392 times
    Here's the pic of what Dustin was sayin'..May take a couple of tries to get it right, but it should work.
  1. Replies: 8
    Last Post: 02-27-2011, 03:22 AM
  2. Droid X is stuck on "Motorola" boot screen
    By danarosetti in forum Droid X Help
    Last Post: 02-19-2011, 09:30 AM
  3. Replies: 13
    Last Post: 12-25-2010, 12:01 PM
  4. Droid X vibrating when set to "never" or "only when in silent mode"
    By First VT Properties in forum Droid X Rescue Squad
    Last Post: 12-05-2010, 05:52 PM
  5. Replies: 5
    Last Post: 10-21-2010, 08:44 AM
activate droid x after factory reset
activating droid x after factory reset
droid x factory reset activate
droid x factory reset activation
droid x factory reset skip activation
how to activate droid x after factory reset
stuck on touch the android to begin
touch the android to begin not working
touch the android to begin stuck
