media player help
This is a discussion on media player help within the Droid X Help forums, part of the Droid X Discussion category; I was trying to play music from droid x through pc speakers. was using windows mwedia play on pc and get message no device detected ...
Results 1 to 2 of 2
Thread: media player help
    lterry913's Avatar
    1569
    132
    Question media player help
    I was trying to play music from droid x through pc speakers. was using windows mwedia play on pc and get message no device detected press f5. did this and nothing happens. when i hooked up droid the computer was only recognizing it as a camera and asked how to manage. any help is appreciated.
    karmajay's Avatar
    237
    USF, FL
    138
    When u hook up your droid x to your computer there are 4 different modes it can be in. it usually defaults to the USB memory stick option. When you hook up to computer I believe you can change mode via the notification bar, change it to PC mode, this should work for you.
  1. Replacement Music Player App?
    By Evelgest in forum Droid X Apps
    Last Post: 08-09-2010, 11:25 AM
  2. Media Managing
    By zactimusprime14 in forum Droid X Help
    Last Post: 07-27-2010, 03:28 PM
  3. Media Volume
    By LexLuthor in forum Droid X Help
    Last Post: 07-23-2010, 03:57 PM
  4. Media share with XP
    By joeyc1123 in forum Droid X Help
    Last Post: 07-23-2010, 09:23 AM
  5. Anyone else notice mis-themed music player?
    By AKValle26 in forum Droid X General Discussion
    Last Post: 07-15-2010, 06:55 PM
can you hook up home speakers to your droidx
can you use computer speakers for android
configure droid to use computer speakers
droid 2 to computer speakers
droid computer speakers
droid x not detected by windows media player
droid x not detected by wmp
play droid x music through computer speakers
play droid x on pc
speakers to hook up to droid
