How do I fix md5 mismatch??
This is a discussion on How do I fix md5 mismatch?? within the Droid X Help forums, part of the Droid X Discussion category; Sorry if this has been posted.did some research the other night but didn't have a lot of time and found no real solution. I installed ...
Results 1 to 8 of 8
Thread: How do I fix md5 mismatch??
    Points: 1,986, Level: 26
    Level completed: 86%, Points required for next Level: 14
    Overall activity: 1.9%
    Bungle's Avatar
    1559
    180
    Question How do I fix md5 mismatch??
    I installed liberty and loved it but decided to go back to stock and had major problems.a series of bad luck. the one I come to the pros with is clockwork recovery gave me a md5 mismatch. my last backup was from november and I lost a lot of serous stuff.how can I get that back in the easiest ENGLISH LANGUAGE way? I saw various solutions but in my limited time on laptop I couldn't figure it out.
    I only have one day off a week and wednesday is it.
    Please help.
    Edit to add: my backup from the night I flashed was the one with the error. I don't think it matters but I installed liberty 1.0 that time.
    Thank you.
    Bungle's Avatar
    1559
    180
    Btw I lost root. (?) Used z4root.
    Edit to add:
    When I emphasized ' in english' I am familiar with everything but if someone says something like: "make sure you wipe", please say what to wipe.I don't do this everyday anymore.
    I will forever be in dept to anyone that helps me fix this.
    come to worcester ma and nights on me drinking. : D
    Points: 2,975, Level: 33
    Level completed: 50%, Points required for next Level: 75
    Overall activity: 0.6%
    drjimbeam's Avatar
    18382
    Lacey WA
    429
    30 times
    if you changed the name of the nandroid change to have no spaces.. should do it
    Bungle's Avatar
    1559
    180
    I didn't change anything. Saw the spaces problem, er solution.haven't changed the name of what clockwork gave it.
    Edit to add:
    I didn't change anything.went from liberty right back to stock.but clockwork gave me md5 error.
    Note to self: after backup, make sure it works before installing roms.
    Points: 51,541, Level: 100
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    If you didn't edit them then you probably have a corrupt backup. You don't have any other backups to try?
    Points: 1,555, Level: 22
    dirtyfingers's Avatar
    26573
    Wisconsin
    125
    The same thing happened to me a couple days ago. It was just a corrupt backup and unfortunately there was nothing I could do. Just restored my prior backup.
    Liberty 1.5, WatermarkD Theme, Black Market, OC'd 1.2 GHz
    Bungle's Avatar
    1559
    180
    my last backup was from november and I had done a lot to the phone since then. Damn.
    Bungle's Avatar
    1559
    180
    Found this on another forum:
    Cupfuloflol wrote:
    You can actually manually do it, and maybe get that backup fixed. Go to the backup folder /sdcard/clockworkmod/backup/*rom name (date and time usually)/
    See if there is a nandroid.md5 file in there. If so, delete it, you can back it up if you want but it is busted so no point.
    Next step to open adb shell or terminal emulator and type:
    Code:
    su
    cd /sdcard/clockworkmod/backup/*rom name (date and time usually)/
    md5sum *img > nandroid.md5
    reboot recovery
    i put in the commands in the emulator and it responded by saying "cannot create nandroid.md5: read-only file system"
    Any idea where to go from here?
  1. Replies: 62
    Last Post: 10-04-2011, 08:14 AM
  2. Replies: 11
    Last Post: 02-15-2011, 07:59 PM
  3. Md5 sum mismatch???
    By dig'em in forum Droid X Help
    Last Post: 01-17-2011, 01:29 PM
  4. Replies: 5
    Last Post: 12-21-2010, 11:38 AM
clockworkmod recovery md5 mismatch
fix md5 mismatch
fix md5 mismatch nandroid restore
how to fix md5 mismatch
how to fix md5 mismatch clockworkmod
how to fix md5 mismatch nandroid restore
md5 mismatch fix
md5 mismatch xrecovery
xrecovery md5 mismatch
