Originally Posted by
gggabs
what is flashing and how do you do it?
thats the one thing that i see that everyone says but i cant figure out what it is..
Its the process of installing a custom rom/firmware/software. And you do this usually through a custom recovery like Droid X bootstrap or Droid 2 Bootstrap
So you root your phone, install bootstrap download your rom or theme boot into recovery through bootstrap then "flash" the rom or theme and then reboot your phone.
If you think you have bricked your phone... do this.... stop look around say a few curse words then take a deep breath because you haven't
we can fix this haha
10-12-2011 09:55 AM
The fact that there is an Android Dictionary made me laugh out loud. Very informative, and seems like it would be invaluable to new people. Sometimes I forget that we use so much lingo.
Need a Video Guide to help root your DX running Gingerbread? CLICK HERE
Need a Video Guide to help restore your DX to stock GB? CLICK HERE If that didn't work, try THIS ONE
Help me
RageXmods
I'm still a NEWBE and don't know what I have after Rooting my Droid X back in January 2011.
My System Version says 2.3.340 (????GingerBread????? I THINK from what I've read here)
Android Version 2.2.1
Kernel Version 2.6.32.9
I occasionally have Problems like Calendar Entries Dissapearing after Entering Them, Telephone Not Dialing or Receiving Incoming Calls, Auto Update for downloaded apps. NOT Working and giving an ERROR Message "Unable to Save or Move to Phone or SD Card" etc. I've found it useful to do a Shutdown or Battery Pull occasionally to correct the Problem, (Similar to a Computer reboot I GUESS!!!) except for the "Auto Update Apps."
I have Installed Z4Root, Superuser, Titanium Backup & SuperManager.
WTF????????????
Do I need to UPDATE the SYSTEM VERSION 2.3.340, OR ANDROID VERSION 2.2.1 OR KERNAL VERSION 2.6.32.9 to another Version or something else?????????????
Yes you can easily update and root your phone again by using the 602 root iso in this link Linux solution to your Windows/RSD lite problems there's a step by step video guide in that link.
