Can't make or receive calls/text messages?
This is a discussion on Can't make or receive calls/text messages? within the Droid X Help forums, part of the Droid X Discussion category; I was on stock .340, did the OTA update. Couple weeks later I wanted to start fresh so I flashed the maderstokc .340 zip to ...
Results 1 to 10 of 10
Thread: Can't make or receive calls/text messages?
    budmonster
    Guest budmonster's Avatar
    Question Can't make or receive calls/text messages?
    I was on stock .340, did the OTA update. Couple weeks later I wanted to start fresh so I flashed the maderstokc .340 zip to get back on clean .340.
    Ever since I've been on maderstokc I've been getting connection problems. I was talking on the phone and all of a sudden my call was dropped. I couldn't make out going calls, it would just sit there and hang. The 3G went away and 1x appear for a while. I could go on the internet and stuff but couldn't receive texts or make phone calls. I did a restore yesterday back to the maderstokc restore I made. Things still didn't work then all of a sudden my 3G came back and I was able to make calls?
    Is something wrong with my phone, is maderstokc messing my phone up? This also has happened when I first got my DX and rooted my phone. There's something going on but I cant point to whats wrong. Any help would be appreciated.
    Thanks- BUD
    Points: 9,994, Level: 66
    Overall activity: 1.2%
    TideFan22's Avatar
    23940
    Florence,Alabama
    3,097
    64 times
    Its not maderstcok, its a form of Sbf it restores back to stock. I think its something with verizons towers or something,, 2 days ago me and alot of people were having 3g problems. I never had call problems though
    Sent from heavily tweaked Rubix!!
    budmonster
    Quote Originally Posted by TideFan22 View Post
    wierd. last night i couldnt make any phone calls it would dial but i couldnt hear anything and it didnt say connected, it would just hang at the screen. this morning it did the same thing until i did a restore. im back on maderstokc but an earlier version. about 30 minutes after i restored it my 3g came back and i was able to make calls, etc.
    right now for some reason my gmail and email on my DX isn't working. i can receive gmail and email messages but i can not send them? i dont know whats going on.
    is there a different way to get back to a clean stock over .340 besides flash maderstokc?
    TideFan22's Avatar
    23940
    Florence,Alabama
    3,097
    64 times
    Sbf
    Sent from Rubix running some tweaked out sysctl.conf
    Points: 3,312, Level: 35
    Level completed: 75%, Points required for next Level: 38
    Eleigh's Avatar
    25897
    136
    Yes same here I've been having signal problems.the bars would go from full bars to nothing at all for a min or two.
    freedup running D@rk$/ĄdŁ 4.2 and sent from †@p@†@/k
    Running Liberty froyo 2.2.1 cause Miui and I are on a break ​LoL
    budmonster
    can you point me to the correct sbf file. i didnt know there was a full .340 sbf out?
    Points: 3,997, Level: 40
    Level completed: 24%, Points required for next Level: 153
    Koopa Troopa's Avatar
    6368
    429
    I had that and a battery pull fixed it.
    budmonster
    Quote Originally Posted by Koopa Troopa View Post
    Ive tried with battery pulls, no luck.
    Moderator
    Points: 25,450, Level: 96
    Frequent Poster
    mikeinrichmond's Avatar
    9010
    Richmond, Va
    7,668
    392 times
    Verizon is doing a lot of work as of late, with the 4G and all, so I don't believe it's your phone. However, you could try reactivating the phone with *228 and option 1 to see if that helps..
    If, after that, you still want to SBF, here is where the files are: There is a link to the install guide there as well. You can ignore the section in the guide on what files to download (since you'll already have them).
    All SBF Files
    Points: 5,156, Level: 46
    Level completed: 3%, Points required for next Level: 194
    Overall activity: 2.8%
    bobniborg's Avatar
    7200
    381
    First, I would ask around with Verizon users in Pitt to see if it is because of work on towers (are they having issues also). I rarely have times where my phone shows 3g but then I try to use the internet and it says nothing is found. I hit my wifi, let it fire up, then shut it off and that usually works.
  1. Replies: 10
    Last Post: 02-17-2011, 06:10 PM
  2. Can't make or receive calls
    By Koopa Troopa in forum Droid X Rescue Squad
    Last Post: 01-05-2011, 01:56 AM
  3. How to receive all incoming calls?
    By eddietee in forum Droid X Help
    Last Post: 11-15-2010, 12:21 PM
  4. Droid wont receive, or make calls or texts, or internet
    By fighterpilot53 in forum Droid X Rescue Squad
    Last Post: 10-21-2010, 02:51 PM
  5. Replies: 3
    Last Post: 10-15-2010, 12:05 PM
droid 2 cant call or text
droid incredible cannot receive calls
droid incredible cant make calls
droidx internet works can't call or text
i cant call or text on my android
i dont want my iphone to recieve calls or text but i want to connect to the internet internationally
page plus droid cant recieve or make calls
verizon iphone wont make calls
verizon iphone wont make calls or send texts
why cant i make calls or send txt but can use internet
