HELP PLEASE -- Cannot turn off "Screen Reader"
This is a discussion on HELP PLEASE -- Cannot turn off "Screen Reader" within the Droid X Help forums, part of the Droid X Discussion category; I was trying different options under Accessibility setting. I turned on "Screen Reader" and it works OK, but now when I hit the "Settings" button ...
Results 1 to 8 of 8
Thread: HELP PLEASE -- Cannot turn off "Screen Reader"
    250 Experience PointsTagger Second Class31 days registered100 Experience Points7 days registered
    Nathan's Avatar
    3320
    23
    I was trying different options under Accessibility setting. I turned on "Screen Reader" and it works OK, but now when I hit the "Settings" button to turn it off, all I get is the verbal word "setting" and it will no longer allow me to enter the settings option.
    Its stuck.
    I rebooted, but no change.
    Help. I need to access the settings menu and I can't.
    I am experiencing the same behavoir also.
    Nathan's Avatar
    3320
    23
    What have you tried?
    Double click on what you want to do and you should be able to navigate back to the settings and change the setting back
    Nathan's Avatar
    3320
    23
    Reverting
    I just kept hitting the key to uncheck the box. After 10-15 hits, it finally reverted back. I'm sure its a bug- will never go that route again.
    myrealtygal's Avatar
    8959
    Quote Originally Posted by cpoe View Post
    OMG! THANK YOU! Thought I'd have to reboot! You get a GOLD star!
    THANK YOU!!!! 2 hours later and listening to that woman's voice I was ready to throw it out the window! I had to hit it many times and much faster than before I read your answer. It sounds like you were really frustrated when you figured that out:>)
    Points: 92, Level: 1
    Level completed: 84%, Points required for next Level: 8
    bonniesac's Avatar
    47750
    Sep 2011
    I just did it! After reading your posts, Just double click each item as it highlights. This seems to only apply to Accessibility settings. It will also change "caller id readout" to ring only, so.. If you like Caller Id readout, as I do, go to Call Settings menu to change the setting.
  1. What's a decent "backup phone" in case I have Droid X issues?
    By Jaxidian in forum Droid X General Discussion
    Last Post: 07-26-2010, 05:27 PM
  2. Replies: 0
    Last Post: 07-22-2010, 01:19 PM
  3. The official "Whats your Home Screen look like?" thread!!!
    By Seven71ne in forum Droid X General Discussion
    Last Post: 07-16-2010, 11:09 AM
  4. Replies: 9
    Last Post: 07-14-2010, 11:48 PM
  5. Replies: 26
    Last Post: 07-14-2010, 07:28 AM
android turn off screen reader
how do i turn off screen reader
how to disable screen reader
how to turn off iphone screen reader
how to turn off screen reader
how to turn off screen reader on iphone
turn off android screen reader
turn off screen reader android
turn off the screen reader
