Flashing green light, no messages/updates
This is a discussion on Flashing green light, no messages/updates within the Droid X Help forums, part of the Droid X Discussion category; Does anyone else get the flashing green message light and then not have any messages or updates? I have looked up threads on this and ...
Results 1 to 9 of 9
Thread: Flashing green light, no messages/updates
    Does anyone else get the flashing green message light and then not have any messages or updates? I have looked up threads on this and most people insist there must be a message or update that the user is missing. But both times it's happened to me I have had the little Facebook icon stuck up across the top, too. Then turning it off makes it disappear and the green light go away. Is this a Facebook app glitch?
    Points: 1,174, Level: 18
    Level completed: 74%, Points required for next Level: 26
    nkair360's Avatar
    1002
    13
    This happens to me a lot too. I don't have any social networking apps and my email and messages are all checked. If i restart it the green blinking will stop.
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    Are you clicking on the menu button and selecting notifications? Is there anything showing up here or do you have the clear button in the top right corner (try pressing this to also clear the LED)? Also, are noticing the flashing with the screen on or off?
    Points: 5,950, Level: 49
    Level completed: 50%, Points required for next Level: 200
    buzzkill's Avatar
    245
    NE Indiana
    107
    im having the same green light issue
    You get a message light when there's a missed call, even if there's no voicemail message.
    Points: 4,788, Level: 44
    joeyjackpot's Avatar
    9452
    1,586
    84 times
    Green light is missed call. If you have a facebook notification, that's what it's notifying you of. Clearing the notification clears the green LED reminder.
    Also, on low battery, you will see a green light as a "sign of life."
    Troubles installing OTA 2.3.340 Update? Click Here
    Created Album pictures
    ebfm2526's Avatar
    24625
    33884
    6
    I get the green led when the screen is OFF to notify of emails from google. I also get this at night when the phone is docked and the flashing light wakes me up! How do I shut off the led when it is docked????
    Points: 66, Level: 1
    Level completed: 32%, Points required for next Level: 34
    Overall activity: 0.0%
    dc138's Avatar
    48501
    Sep 2011
    finally figure it out
    I have a X2. Finally figure it out. When it starts to check for any program update, if find any new update, the green light will flash. After it finds all the updates, then you will see the notification. Simply read that notification will clear the flashing green light.
    I chased the elusive flashing green light for a couple of days. After checking for what I have before found to cause it, like missed calls, text messages, voicemails, droid updates, and email alerts numerous times, I finally found it in my case. Because i have and use gmail calendar and have entries in there, the flashing green light was a notification coming from one my the entries. Went through and deleted and/or changed the notifications on the event and light quit flashing. Drove me nuts by the way.
  1. Not working, just a green light.
    By smiley68 in forum Droid X Help
    Last Post: 02-26-2013, 04:42 PM
  2. updates 7/24?
    By evilized in forum Droid X General Discussion
    Last Post: 07-25-2010, 07:51 AM
  3. Flashing green bar at top during call
    By droidxer in forum Droid X General Discussion
    Last Post: 07-23-2010, 04:44 PM
  4. Flashing Green notification bar while on the phone - NOT Flashing LED!!!
    By Phatkat66 in forum Droid X General Discussion
    Last Post: 07-23-2010, 09:31 AM
  5. Anyway to keep Green LED light on?
    By jtdiddy in forum Droid X General Discussion
    Last Post: 07-22-2010, 04:22 PM
droid green light keeps flashing
droid x2 flashing green light
droid x2 green light flashing
droid x2 notification light keeps blinking
green flashing light on droid
how to prevent green light flashing on my droid x2
motorola droid x2 led light flashing when no message
why does a green light keep blinking on my droid x2
why does the green light flash on my droid
why does the green light on my droid keep flashing
