Flashing Boot Animation/Removing Previous Boot Animations
This is a discussion on Flashing Boot Animation/Removing Previous Boot Animations within the Droid X Help forums, part of the Droid X Discussion category; Having problems with boot animation. I successfully flashed the Thunderbolt boot animation with clockwork. Problem now is I'd like to switch it up. Been trying ...
Results 1 to 10 of 11
Like Tree4Likes
Thread: Flashing Boot Animation/Removing Previous Boot Animations
    Balticzar's Avatar
    3066
    42
    Having problems with boot animation. I successfully flashed the Thunderbolt boot animation with clockwork. Problem now is I'd like to switch it up. Been trying to flash different ones using the same process through clockwork but they wont take despite it saying it completed. Any help greatly appreciated. How can I remove it or flash over it? Thanks guys.
    Running Liberty 1.5 if that matters.
    Points: 5,955, Level: 50
    Level completed: 3%, Points required for next Level: 195
    scottpole's Avatar
    27229
    1,119
    38 times
    I can't find the app I use on the market but it's on 4shared.com. go there and download boot animation changer. Then click backup your installed boot animation. This will create a new folder on your sd card and place a copy of your current boot animation. The folder should be called backupbootanimation. Now just delete the backup and replace with the boot animation you want to install. Finally click install backup boot animation reboot and enjoy!
    Uploaded from my Blurry X ~_~
    Balticzar likes this.
    Warm Gingerbread with super user icing
    Points: 5,156, Level: 46
    Level completed: 3%, Points required for next Level: 194
    Overall activity: 2.8%
    bobniborg's Avatar
    7200
    381
    where you getting all your boot ani's from? Do they have sound?
    Balticzar's Avatar
    3066
    42
    Thanks scottpole I'll give that a shot. Not sure what the heck I did but now my market is not working. I'll have to get that going first now. I had flashed a dark themed market and now with me messing around flashing like there's no tomorrow I messed that up somehow.
    Balticzar's Avatar
    3066
    42
    Bobniborg, no soound on the boot ani's yet. Haven't figured that out. But one boot I got from xda and the other from samdroid.
    Points: 9,494, Level: 65
    Level completed: 48%, Points required for next Level: 156
    skennelly's Avatar
    17443
    Illinois
    1,319
    44 times
    Quote Originally Posted by Balticzar View Post
    Easiest thing to do is find the boot animation you want (has to be a .zip) and save it to your sdcard. Change the name of the dl'ed file to bootanimation.zip (no caps). Open root explorer, find that file and move it to the data>local folder and replace the current bootanimation.zip file there. Reboot and you're done.
    Sent from my DROID X in Western Illinois
    Balticzar's Avatar
    3066
    42
    Thanks. That actually sounds super easy. Thanks. First imma fix my market force closing then, I'll tackle that.
    skennelly's Avatar
    17443
    Illinois
    1,319
    44 times
    I meant to mention that I am on liberty, not sure if that makes a difference, or if it is univesal to all roms.
    mandog202's Avatar
    25661
    Huntsville AL
    261
    20 times
    Liberty users can also save it to the sd card as bootanimation.zip, then go to liberty toolbox > liberty tweaks > manage boot animation > install /sdcard/bootanimation.zip, reboot, and enjoy.
    bobniborg's Avatar
    7200
    381
    search you phone with root explorer or one of those programs for bootanimation.zip
    then move or rename that one and put in the new one
  1. Replies: 35
    Last Post: 10-08-2011, 10:38 AM
  2. Here are some custom easy boot animations.
    By Casen in forum Droid X Themes
    Last Post: 08-08-2011, 11:19 PM
  3. [BOOT ANIMATION] Boot Animation(s) by chkmate!!!
    By chkmate in forum Droid X Hacks
    Last Post: 02-19-2011, 04:50 PM
  4. Looking For Help On How To Make Custom Boot Animations
    By Flazell in forum Droid X Hacks
    Last Post: 02-13-2011, 04:52 PM
  5. Do something special to boot animations?
    By Explodee in forum Droid X Help
    Last Post: 09-29-2010, 01:13 PM
flash a boot animation
flash boot animation
flashing boot animation
how to flash a boot animation
how to flash a custom boot animation
how to flash a new boot animation
how to flash boot animation
how to flash boot animations
how to remove custom boot animation
remove thunderbolt boot animation
