Using DLNA disconnects WIFI everytime . . . ?
This is a discussion on Using DLNA disconnects WIFI everytime . . . ? within the Droid X Help forums, part of the Droid X Discussion category; Can't get dlna to work consistently. I usually can connect it to my PS3 and my xbox360, which I do for the purpose of streaming ...
Results 1 to 1 of 1
Thread: Using DLNA disconnects WIFI everytime . . . ?
    Points: 917, Level: 16
    250 Experience Points100 Experience Points31 days registeredTagger Second Class7 days registered
    bladerunn3r's Avatar
    25364
    21
    Angry Using DLNA disconnects WIFI everytime . . . ?
    Can't get dlna to work consistently. I usually can connect it to my PS3 and my xbox360, which I do for the purpose of streaming music to those consoles. However, my wifi drops out after a couple of minutes, or at best 15-20 minutes. In the DLNA menu settings, I have "xbox" button turned on, as well as "keep wifi" connection turned on. Wifi works great otherwise; it is only when DLNA is turned on that wifi drops out/turns off.
    NOTE: I posted this question about a month ago here, and thought it had been fixed by turning the "sync" funtion on my phone to "off." The celebration was premature--it did not fix the problem. Any ideas/suggestions? Thanks.
  1. Turning on DLNA kills wifi after 15 minutes? Everytime.
    By bladerunn3r in forum Droid X Help
    Last Post: 01-14-2011, 11:02 AM
  2. Wifi frequently disconnects?
    By Drummynator in forum Droid X Help
    Last Post: 10-23-2010, 12:57 PM
  3. Droid X on reboot....boots into Bootstrap everytime HELP!
    By ShadowDroid in forum Droid X Hacks
    Last Post: 10-10-2010, 11:18 PM
  4. DLNA disconnects
    By csuScorp in forum Droid X Help
    Last Post: 08-21-2010, 02:01 PM
  5. Replies: 2
    Last Post: 08-14-2010, 09:52 AM
Dlna droid
android dlna disconnects
atrix wifi disconnecting
dlna disconnecting
dlna disconnects
dlna droid x
dlna keeps disconnecting
droid dlna
droid x wifi fix
droid x2 wifi disconnects
