Problem with SD card.
This is a discussion on Problem with SD card. within the Droid X Help forums, part of the Droid X Discussion category; About a week or so ago, my phone randomly shut off and then started to reboot. It got stuck at the motorola (M) screen and ...
  • 1 Post By DebianDog
Thread: Problem with SD card.
    About a week or so ago, my phone randomly shut off and then started to reboot. It got stuck at the motorola (M) screen and stayed there. I tried everything I could to get it to come back, until I finally removed my SD card. Only then did it turn back on. Now, I cannot turn the phone on at all while the SD card is inserted. Is there any way to fix this or do I need a new card?
    Points: 7,762, Level: 59
    Overall activity: 1.2%
    mopar-x's Avatar
    22071
    Buffalo N.Y.
    1,132
    56 times
    I have heard of SD card issues it sound's like you may have a bum card but maybe someone's got a fix for you. Just give it moment and I'm sure someone more knowledgeable than I will help you out. (Hold music)
    Sent from Mopar-x
    Rescue Squad
    Points: 42,712, Level: 100
    DebianDog's Avatar
    6359
    "The Sticks", Virginia
    4,384
    332 times
    Just so I am clear... the phone works with it out?
    Yes, it works just fine without the SD card.
    Rescue Squad
    DebianDog's Avatar
    6359
    4,384
    332 times
    Yeah sounds like a bad card. You can buy a cheap (like $3 at Walmart) card reader and see if the computer reads it at all.
  1. HELP!! Sd card problem!
    By mapileTree in forum Droid X ROMs
    Last Post: 07-30-2011, 11:47 AM
  2. Replies: 3
    Last Post: 12-25-2010, 11:17 AM
  3. DROID X 2.2 VIDEO on 16 G SD Card but not 32 G SD Card
    By Diablo98 in forum Droid X Audio / Video
    Last Post: 11-06-2010, 04:57 PM
  4. Problem with media dock and SD card
    By Tony.oe in forum Droid X Help
    Last Post: 09-30-2010, 04:07 PM
  5. Problem with my sd card
    By PorcPuffer in forum Droid X Help
    Last Post: 07-18-2010, 01:21 PM
blank sd card droid x fix
blank sd card fix
droid x blank sd card fix
droid x gingerbread blank sd
droid x not turning on what do i need to have on sd card
droid x problems with sd card
droid x sd card problem
droid x sd card problems
droidx sd card blank fix
sd card malfunction
