Unfriendly calendar
This is a discussion on Unfriendly calendar within the Droid X Help forums, part of the Droid X Discussion category; Having come from BlackBerry, I find the calendar rather user unfriendly. I need to insert my work schedule which is identical every other week. There ...
Thread: Unfriendly calendar
    Unfriendly calendar
    Having come from BlackBerry, I find the calendar rather user unfriendly. I need to insert my work schedule which is identical every other week. There is no repeat selection that is for every other week. Also, there appears to be no go-to function to jump to a certain date. If I have overlooked something, please help.
    Points: 1,681, Level: 23
    Level completed: 81%, Points required for next Level: 19
    250 Experience Points31 days registered100 Experience PointsTagger Second Class7 days registered
    sherylhs's Avatar
    783
    Michigan
    34
    If you go to the calendar option from your gmail account (on your computer) put in your work schedule; under repeat select weekly. You will see additional options, including "Repeat Every ______ Week", just select 2 from the dropdown box.
    I don't know if this works the same way on the phone, I usually add my big stuff on the computer and then just let it sync to my phone.
    ~S
    P.S. Welcome to the forums. ~waves~
    Points: 1,828, Level: 25
    Level completed: 28%, Points required for next Level: 72
    250 Experience Points100 Experience Points31 days registered7 days registeredTagger Second Class
    pliSkiNAKE's Avatar
    1237
    Chicago
    15
    The calendar is more unfriendly with ending a daily (or any repeating) occurrence. There's no end date for an event when you want it to reoccur. Unfortunately my original post on this wasn't replied to and it's many pages down. I guess I wasn't looking for anything but confirmation on this. To make sure I wasn't missing something. Or if there was an alternative that I could use that'd be better (on my phone, not on the PC).
    If I ever do find a replacement calendar that's better, I'll reply with it here.
    I see that you can do this on the computer, but it seems as if you should have the same options on the phone.
    Points: 1,207, Level: 19
    Level completed: 7%, Points required for next Level: 93
    antintyty's Avatar
    1168
    Smalltown, USA
    49
    i came from a blackberry too, and i just dl'd the app called Jorte, it's AWESOME...one simple word....awesome!
  1. Calendar App
    By Chris in forum Droid X General Discussion
    Last Post: 08-25-2010, 06:42 PM
  2. Contacts and calendar questions
    By pm1066 in forum Droid X Help
    Last Post: 08-01-2010, 05:59 PM
  3. Calendar App
    By Chris in forum Droid X Help
    Last Post: 07-22-2010, 01:54 PM
  4. Calendar Notifications?
    By JerryC in forum Droid X Apps
    Last Post: 07-20-2010, 11:01 AM
  5. Simple Calendar Question
    By Ansextra in forum Droid X General Discussion
    Last Post: 07-16-2010, 08:12 AM
calendar apps that allow repeat every other week
calendar on droid x does not have every other week
droid every other week app
droid razr calendar no end date for recurring appointment
droid recurring events, every other week, calendar
droid x calendar alternative
droid x calendar event for every other week
droid x calendar repeat every other week
facebook+login+welcome mobile
how do you repeat every 2 weeks on droid x calendar
