New User, Need Help. Droid Icon and Triangle with Exclamation!
This is a discussion on New User, Need Help. Droid Icon and Triangle with Exclamation! within the Droid X Help forums, part of the Droid X Discussion category; Went to use my phone today and it was shut off. I thought I should of had enough battery left so I was confused. I ...
Results 1 to 10 of 11
Like Tree4Likes
Thread: New User, Need Help. Droid Icon and Triangle with Exclamation!
    Ty_Man's Avatar
    27869
    6
    Went to use my phone today and it was shut off. I thought I should of had enough battery left so I was confused. I went to plug in the charger and turn it on and I have a droid icon and a triangle with and exclamation point inside.
    I can't seem to get rid of it and turn the phone on. I'm getting pretty concerned. Is my phone bricked?
    Rescue Squad
    Points: 32,688, Level: 100
    DebianDog's Avatar
    6359
    "The Sticks", Virginia
    4,384
    332 times
    Press the Search key
    Points: 1,565, Level: 22
    Level completed: 65%, Points required for next Level: 35
    Overall activity: 1.1%
    sambobber2's Avatar
    19049
    117
    Have you done any modding to it? Like root, flash, ROM, etc?
    Ty_Man likes this.
    Points: 7,762, Level: 59
    Overall activity: 1.2%
    mopar-x's Avatar
    22071
    Buffalo N.Y.
    1,132
    56 times
    You have to let it charge for 30 to 60 minutes before you try to turn it back on. Try that first.
    Ty_Man likes this.
    Sent from Mopar-x
    Ty_Man's Avatar
    27869
    6
    No, I'm a real noobie when it comes to nice phones like this. I kinda went nuts with installing a bunch of apps, not too many mind you, but I havn't done any of that stuff yet because I don't know anything about rooting or getting a ROM emulator, etc.
    Ty_Man's Avatar
    27869
    6
    What do you think could have caused this? So I can avoid it in the future.
    Points: 1,517, Level: 22
    3 months registered31 days registered100 Experience Points7 days registeredTagger Second Class
    usmc7356's Avatar
    1562
    Austin, TX
    122
    When you get to that point that you want to put root and a custom rom on it you are in a great place to get help. It is not nearly as hard as it sounds. Id be happy to help if you wanna pm me with questions too.
    $wĄp€d on my liberated x using the dxf app
    Ty_Man likes this.
    Ty_Man's Avatar
    27869
    6
    PHONE STARTED! I let it charge for a while, pulled out the battery, (found info on older post guy had with same problem) and it rebooted. Pressing the search button didn't work.
    Thread can end here. Thanks for anyone who helped.
    mopar-x's Avatar
    22071
    Buffalo N.Y.
    1,132
    56 times
    I'm happy you got it going!!
    Sent from Mopar-x
    Points: 58, Level: 1
    Level completed: 16%, Points required for next Level: 42
    Overall activity: 0.0%
    csportsman's Avatar
    48679
    Sep 2011
    Hi, I just ran across this thread and wanted to put the solution I found on here in case it will help anyone else.
    I went to charge my phone this morning and got only the icon with the little droid robot and a triangle with an exclamation point in it. I can't remember what colors they were. Anyway, I read the forums and tried to figure it out, but they didn't help. I took out my battery, but the little icon stayed on my screen. I put the battery back in and it stayed on my screen. I took it out for about 5 minutes, and it was still on my screen. (It must have some internal battery for it to have stayed up like that...)
    Anyway, I remembered that I had taken my SD card out the day before, so I took it out and put it back in, unplugged my phone from the charger, put the battery back in, put the cover back on and plugged my phone back up. It gave me the low battery icon rather than the droid/exclamation point icon this time, so I booted the phone up. I haven't had any more trouble after that.
    I don't know what I did that fixed it, but thankfully I didn't have to call Verizon and get another one! Now time to do my backup after that panic of thinking I was going to have to do a whole system re-do and lose everything!
  1. Droid icon and exclamation triangle screen
    By Carpetman in forum Droid X Hacks
    Last Post: 06-25-2011, 10:48 AM
  2. Brand New User - Messaging icon on main screen
    By seattleike in forum Droid X Help
    Last Post: 12-27-2010, 02:57 PM
  3. Replies: 19
    Last Post: 12-04-2010, 01:01 PM
  4. Droid X Blue Triangle after SBF
    By Shamrock in forum Droid X Rooted Issues
    Last Post: 11-01-2010, 07:15 PM
  5. First time Droid user...coming from a BB user
    By mark5 in forum New Member Introductions & Site Assistance
    Last Post: 08-26-2010, 09:58 PM
android icon triangle exclamation
android icon triangle exclamation point
android robot exclamation point inside triangle
android robot with a triangle with an exclamation mark inside
android symbol triangle with exclamation point
android symbol with triangle and exclamation point
android triangle icon
droid triangle icon
droid x triangle with exclamation point
