Transferring music
This is a discussion on Transferring music within the Droid X Help forums, part of the Droid X Discussion category; I recently bought a 32 gb sd card and installed it. It works great but I'm having an issue when transferring music to it. I'm ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Like Tree6Likes
Thread: Transferring music
    250 Experience Points3 months registered31 days registered7 days registered100 Experience Points
    Starman2112's Avatar
    26441
    24
    Transferring music
    I recently bought a 32 gb sd card and installed it. It works great but I'm having an issue when transferring music to it. I'm doing a copy and paste from my iTunes library to the memory card but some the songs on some of the albums don't show up in the correct order. Some of the albums have the songs in alphabeticle order rather than the order they are on the album.
    Anyone know how I can fix this? Thanks in adnavce!
    26441
    24
    Well, I think I've discovered the problem. For whatever reason, if you import an entire album by a band as MP3 files they will show up in the same playing order as the original album. But if you import any other type of audio file it will list the songs by album, but in alphabeticle order. It took quite a bit of trial and error but I figured it out! lol
    Now, the time consuming part: Using iTunes to convert about 4000 songs to MP3 format then import them! WHEW!
    Advocate X Achievements:
    The persuader's Avatar
    12986
    Maine
    5,603
    66 times
    Here's some options...
    You need to Download iSyncr Lite from the Market or get the paid version...
    Second..this is the Gatekeeper to transfer your music to your phone...
    Third...DOWNLOAD MonkeyMedia to your laptop...then MM will ask to transfer your music from I-tunes...obviously Yes is the choice...
    Fourth...Open iSyncr...this should prompt you the rest of the way thru to download all your music to your phone...not sure you can D-Load all 4000...
    Check with D Xer too...he helped me with this Market App's
    It's Bubba
    Starman2112 likes this.
    "Stubborn In You're Bones"
    26441
    24
    Thanks for the info! I'll be looking into all of it!
    Points: 51,541, Level: 100
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Just buy iSyncer the full version. Its like $3 but makes everything so easy. Download the app and connect to PC, drag your music over to iSyncer, it'll transfer everything over and you will keep albums, artists, etc in order.
    26441
    24
    More great info! Thanks!
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Sure thing. I tried several other apps paid and free/lite versions, but iSynver was by far the easiest to use and kept everything in order which satisfied my OCD!
    Advocate X
    Points: 24,548, Level: 95
    Overall activity: 31.6%
    WugFresh's Avatar
    19823
    Earth
    5,135
    455 times
    MediaMonkey is great if your a Windows user, ditch iTunes for good and stop running four background processes. With MediaMonkey you don't need iSyncr, it supports full android syncing capabilities:
    Here's some info:
    MediaMonkey Info
    If you need to strip DRM
    SoundTaxi Info
    To sync MediaMonkey
    http://forums.precentral.net/webos-s...ml#post2228391 ... Just mount as mass storage
    {{ WugFresh }}
    Other helpful resources:
    Points: 1,037, Level: 17
    Level completed: 37%, Points required for next Level: 63
    nycebo's Avatar
    17290
    103
    Another option is just to long hold the name of the album and press play. It'll play the songs in order then.
    12986
    Maine
    5,603
    66 times
    WugFresh...D X'er
    Learned other option on this Post...
    Thanks
    It's Bubba
  1. Transferring music to poweramp
    By droidxer in forum Droid X Apps
    Last Post: 12-16-2010, 02:23 PM
  2. Help Transferring Itunes Music to Droid X
    By obert272 in forum Droid X Help
    Last Post: 10-11-2010, 02:31 PM
  3. My music folders won't show up when transferring songs?
    By ForsakenFalcon in forum Droid X Help
    Last Post: 09-04-2010, 02:06 AM
  4. Ah Ha -- transferring pictures and music from MAC
    By redoil in forum Droid X Help
    Last Post: 08-21-2010, 05:19 AM
  5. transferring music
    By powderchopper in forum Droid X General Discussion
    Last Post: 08-02-2010, 12:24 PM
droid x does copy music error
isyncr error 31
isyncr error 62
isyncr error code 31
isyncr error code 6
isyncr error code 6#gsc.tab
isyncr error code 62
isyncr error code 7
poweramp transfering songs
transferring music using power amp
